# HomeKit Add-on
- Switchable
- Outlet
- Fan
- Thermostat
- Heater / Cooler
- Lock
- Security System
- Garage Door Opener
- Motorized Door
- Motorized Window
- Window Covering/Blinds
- Valve
- Air Quality Sensor
- Contact Sensor
- Leak Sensor
- Motion Sensor
- Occupancy Sensor
- Smoke Sensor
- Temperature Sensor
- Humidity Sensor
- Light Sensor
- Carbon Dioxide Sensor
- Carbon Monoxide Sensor
Attention: Some tags have been renamed. Old style may not be supported in future versions. See below for details.
# Global Configuration
Your first step will be to create the homekit.cfg in your $OPENHAB_CONF/services folder.
At the very least, you will need to define a pin number for the bridge.
This will be used in iOS when pairing. The pin code is in the form "###-##-###".
If your home network is secure, a good starting point is the pin code used in most sample applications: 031-45-154.
Check for typos in the pin-code if you encounter "Bad Client Credential" errors during pairing.
Other settings, such as using Fahrenheit temperatures, customizing the thermostat heat/cool/auto modes, and specifying the interface to advertise the HomeKit bridge (which can be edited in Paper UI standard mode) are also illustrated in the following sample:
org.openhab.homekit:port=9124
org.openhab.homekit:thermostatTargetModeCool=CoolOn
org.openhab.homekit:thermostatTargetModeHeat=HeatOn
org.openhab.homekit:thermostatTargetModeAuto=Auto
org.openhab.homekit:thermostatTargetModeOff=Off
The following additional settings can be added or edited in Paper UI after switching to expert mode:
org.openhab.homekit:minimumTemperature=-100
org.openhab.homekit:maximumTemperature=100
# Overview of all settings
| networkInterface | IP address or domain name under which the HomeKit bridge can be reached. If no value is configured, the add-on uses the first network adapter address. | (none) |
| startDelay | HomeKit start delay in seconds in case the number of accessories is lower than last time. This helps to avoid resetting home app in case not all items have been initialised properly before HomeKit integration start. | 30 |
| useFahrenheitTemperature | Set to true to use Fahrenheit degrees, or false to use Celsius degrees. | false |
| thermostatTargetModeCool | Word used for activating the cooling mode of the device (if applicable). | CoolOn |
| thermostatTargetModeHeat | Word used for activating the heating mode of the device (if applicable). | HeatOn |
| thermostatTargetModeAuto | Word used for activating the automatic mode of the device (if applicable). | Auto |
| thermostatTargetModeOff | Word used to set the thermostat mode of the device to off (if applicable). | Off |
| minimumTemperature | Lower bound of possible temperatures, used in the user interface of the iOS device to display the allowed temperature range. Note that this setting applies to all devices in HomeKit. | -100 |
| maximumTemperature | Upper bound of possible temperatures, used in the user interface of the iOS device to display the allowed temperature range. Note that this setting applies to all devices in HomeKit. | 100 |
A HomeKit accessory has mandatory and optional characteristics (listed below in the table). The mapping between openHAB items and HomeKit accessory and characteristics is done by means of tagging. You can tag openHAB items using:
- tags (opens new window) (deprecated)
- metadata (opens new window)
e.g.
Switch leaksensor_tag "Leak Sensor with Tag" [ "LeakSensor" ]
The HomeKit integration currently supports both options. You can mix both options in the same configuration file.
If an openHAB item has both, tags and metadata, then HomeKit integration will use only metadata and ignore tags.
In general, the tag way is considered legacy and may be removed in future releases.
You can link one openHAB item to one or more HomeKit accessory, e.g.
The tag can be:
If the shorthand version has only a characteristic then it must be a part of a group which has a HomeKit accessory type. You can use openHAB group to define complex accessories. The group item must indicate the HomeKit accessory type, e.g. LeakSensor definition using tags
Group gLegacy_leaksensor "Legacy Leak sensor Group" [ "LeakSensor" ]
Switch legacy_leaksensor "Legacy Leak sensor" (gLegacy_Leaksensor) [ "LeakDetectedState" ]
Switch legacy_leaksensor_battery "Legacy Leak sensor battery status" (gLegacy_Leaksensor) [ "homekit:BatteryLowStatus" ]
using metadata
You can use openHAB group to manage state of multiple items. (see Group items (opens new window)) In this case, you can assign HomeKit accessory type to the group and to the group items Following example defines 3 HomeKit accessories of type Lighting:
- "Light 1" and "Light 2" as independent lights
- "Light Group" that controls "Light 1" and "Light 2" as group
Switch light1 "Light 1" (gLight) {homekit="Lighting.OnState"}
Switch light2 "Light 2" (gLight) {homekit="Lighting.OnState"}
# Supported accessory type
| Accessory Tag | Mandatory Characteristics | Optional Characteristics | Supported OH items | Description |
| AirQualitySensor | Air Quality Sensor which can measure different parameters | |||
| AirQuality | String | Air quality state, possible values (UNKNOWN,EXCELLENT,GOOD,FAIR,INFERIOR,POOR). Custom mapping can be defined at item level, e.g. [EXCELLENT="BEST", POOR="BAD"] | ||
| OzoneDensity | Number | Ozone density in micrograms/m3, max 1000 | ||
| NitrogenDioxideDensity | Number | NO2 density in micrograms/m3, max 1000 | ||
| SulphurDioxideDensity | Number | SO2 density in micrograms/m3, max 1000 | ||
| PM25Density | Number | PM2.5 micrometer particulate density in micrograms/m3, max 1000 | ||
| PM10Density | Number | PM10 micrometer particulate density in micrograms/m3, max 1000 | ||
| VOCDensity | Number | VOC Density in micrograms/m3, max 1000 | ||
| Name | String | Name of the sensor | ||
| ActiveStatus | Switch, Contact | Working status | ||
| FaultStatus | Switch, Contact | Fault status | ||
| TamperedStatus | Switch, Contact | Tampered status | ||
| BatteryLowStatus | Switch, Contact | Battery status | ||
| LeakSensor | Leak Sensor | |||
| LeakDetectedState | Switch, Contact | Leak sensor state (ON=Leak Detected, OFF=no leak) | ||
| MotionSensor | Motion Sensor | |||
| MotionDetectedState | Switch, Contact | Motion sensor state (ON=motion detected, OFF=no motion) | ||
| OccupancySensor | Occupancy Sensor | |||
| OccupancyDetectedState | Switch, Contact | Occupancy sensor state (ON=occupied, OFF=not occupied) | ||
| ContactSensor | Contact Sensor,An accessory with on/off state that can be viewed in HomeKit but not changed such as a contact sensor for a door or window | |||
| ContactSensorState | Switch, Contact | Contact sensor state (ON=open, OFF=closed) | ||
| SmokeSensor | Smoke Sensor | |||
| SmokeDetectedState | Switch, Contact | Smoke sensor state (ON=smoke detected, OFF=no smoke) | ||
| LightSensor | Light sensor | |||
| LightLevel | Number | Light level in lux | ||
| HumiditySensor | Relative Humidity Sensor providing read-only values | |||
| RelativeHumidity | Number | Relative humidity in % between 0 and 100. additional configuration homekitMultiplicator = | ||
| TemperatureSensor | Temperature sensor | |||
| CurrentTemperature | Number | current temperature. supported configuration: minValue, maxValue, step. | ||
| CarbonDioxideSensor | Carbon Dioxide Sensor | |||
| CarbonDioxideDetectedState | Switch, Contact | carbon dioxide sensor state (ON- abnormal level of carbon dioxide detected, OFF - level is normal) | ||
| CarbonDioxideLevel | Number | Carbon dioxide level in ppm, max 100000 | ||
| CarbonDioxidePeakLevel | Number | highest detected level (ppm) of carbon dioxide detected by a sensor, max 100000 | ||
| CarbonMonoxideSensor | Carbon monoxide Sensor | |||
| CarbonMonoxideDetectedState | Switch, Contact | Carbon monoxide sensor state (ON- abnormal level of carbon monoxide detected, OFF - level is normal) | ||
| CarbonMonoxideLevel | Number | Carbon monoxide level in ppm, max 100 | ||
| CarbonMonoxidePeakLevel | Number | highest detected level (ppm) of carbon monoxide detected by a sensor, max 100 | ||
| Door | Motorized door. One Rollershutter item covers all mandatory characteristics. see examples below. | |||
| CurrentPosition | Rollershutter | Current position of motorized door | ||
| TargetPosition | Rollershutter | Target position of motorized door | ||
| PositionState | Rollershutter | Position state. Supported states: DECREASING, INCREASING, STOPPED. Mapping can be redefined at item level, e.g. [DECREASING="Down", INCREASING="Up"]. If no state provided, "STOPPED" is used. | ||
| Name | String | Name of the motorized door | ||
| HoldPosition | Switch | Motorized door should stop at its current position. A value of ON must hold the state of the accessory. A value of OFF should be ignored. | ||
| ObstructionStatus | Switch, Contact | Current status of obstruction sensor. ON-obstruction detected, OFF - no obstruction | ||
| Window | Motorized window. One Rollershutter item covers all mandatory characteristics. see examples below. | |||
| CurrentPosition | Rollershutter | Current position of motorized window | ||
| TargetPosition | Rollershutter | Target position of motorized window | ||
| Name | String | Name of the motorized window | ||
| WindowCovering | Window covering / blinds. One Rollershutter item covers all mandatory characteristics. see examples below. | |||
| CurrentPosition | Rollershutter | Current position of window covering | ||
| TargetPosition | Rollershutter | Target position of window covering | ||
| PositionState | Rollershutter | current only "STOPPED" is supported. | ||
| Name | String | Name of the windows covering | ||
| HoldPosition | Switch | Window covering should stop at its current position. A value of ON must hold the state of the accessory. A value of OFF should be ignored. | ||
| CurrentHorizontalTiltAngle | Number | current angle of horizontal slats for accessories windows. values -90 to 90. A value of 0 indicates that the slats are rotated to a fully open position. A value of -90 indicates that the slats are rotated all the way in a direction where the user-facing edge is higher than the window-facing edge. | ||
| TargetHorizontalTiltAngle | Number | target angle of horizontal slats | ||
| CurrentVerticalTiltAngle | Number | current angle of vertical slats | ||
| TargetVerticalTiltAngle | Number | target angle of vertical slats | ||
| Switchable | An accessory that can be turned off and on. While similar to a lightbulb, this will be presented differently in the Siri grammar and iOS apps | |||
| OnState | Switch | State of the switch - ON/OFF | ||
| Name | String | Name of the switch | ||
| Outlet | An accessory that can be turned off and on. While similar to a lightbulb, this will be presented differently in the Siri grammar and iOS apps | |||
| OnState | Switch | State of the outlet - ON/OFF | ||
| InUseStatus | Switch | indicates whether current flowing through the outlet | ||
| Lighting | A lightbulb, can have further optional parameters for brightness, hue, etc | |||
| OnState | Switch | State of the light - ON/OFF | ||
| Name | String | Name of the light | ||
| Hue | Dimmer, Color | Hue | ||
| Saturation | Dimmer, Color | Saturation in % (1-100) | ||
| Brightness | Dimmer, Color | Brightness in % (1-100). See "Usage of dimmer modes" for configuration details. | ||
| ColorTemperature | Number | Color temperature which is represented in reciprocal megaKelvin, values - 50 to 400. should not be used in combination with hue, saturation and brightness | ||
| Fan | Fan | |||
| ActiveStatus | Switch | accessory current working status. A value of "ON"/"OPEN" indicates that the accessory is active and is functioning without any errors. | ||
| CurrentFanState | Number | current fan state. values: 0=INACTIVE, 1=IDLE, 2=BLOWING AIR | ||
| TargetFanState | Number | target fan state. values: 0=MANUAL, 1=AUTO | ||
| RotationDirection | Number, Switch | rotation direction. values: 0/OFF=CLOCKWISE, 1/ON=COUNTER CLOCKWISE | ||
| RotationSpeed | Number, Dimmer | fan rotation speed in % (1-100) | ||
| SwingMode | Number, Switch | swing mode. values: 0/OFF=SWING DISABLED, 1/ON=SWING ENABLED | ||
| LockControl | Number, Switch | status of physical control lock. values: 0/OFF=CONTROL LOCK DISABLED, 1/ON=CONTROL LOCK ENABLED | ||
| Thermostat | A thermostat requires all mandatory characteristics defined below | |||
| CurrentTemperature | Number | current temperature. supported configuration: minValue, maxValue, step | ||
| TargetTemperature | Number | target temperature. supported configuration: minValue, maxValue, step | ||
| CurrentHeatingCoolingMode | String | Current heating cooling mode (OFF, AUTO, HEAT, COOL). for mapping see homekit settings above. | ||
| TargetHeatingCoolingMode | String | Target heating cooling mode (OFF, AUTO, HEAT, COOL). for mapping see homekit settings above. | ||
| Name | String | Name of the thermostat | ||
| CoolingThresholdTemperature | Number | maximum temperature that must be reached before cooling is turned on. min/max/step can configured at item level, e.g. minValue=10.5, maxValue=50, step=2] | ||
| HeatingThresholdTemperature | Number | minimum temperature that must be reached before heating is turned on. min/max/step can configured at item level, e.g. minValue=10.5, maxValue=50, step=2] | ||
| HeaterCooler | Heater or/and cooler device | |||
| CurrentHeaterCoolerState | String | current heater/cooler mode (INACTIVE, IDLE, HEATING, COOLING). Mapping can be redefined at item level, e.g. [HEATING="HEAT", COOLING="COOL"] | ||
| TargetHeaterCoolerState | String | target heater/cooler mode (AUTO, HEAT, COOL). Mapping can be redefined at item level, e.g. [AUTO="AUTOMATIC"] | ||
| Name | String | Name of the heater/cooler | ||
| RotationSpeed | Number | fan rotation speed in % (1-100) | ||
| Lock | A Lock Mechanism | |||
| LockCurrentState | Switch, Number | current state of lock mechanism (1/ON=SECURED, 0/OFF=UNSECURED, 2=JAMMED, 3=UNKNOWN) | ||
| LockTargetState | Switch | target state of lock mechanism (ON=SECURED, OFF=UNSECURED) | ||
| Name | String | Name of the lock | ||
| Valve | Valve. additional configuration: homekitValveType = ["Generic", "Irrigation", "Shower", "Faucet"] | |||
| InUseStatus | Switch | indicates whether fluid flowing through the valve. A value of "ON"/"OPEN" indicates that fluid is flowing. | ||
| Duration | Number | defines how long a valve should be set to ʼIn Useʼ in second. You can define the default duration via configuration homekitDefaultDuration = | ||
| RemainingDuration | Number | describes the remaining duration on the accessory. the remaining duration increases/decreases from the accessoryʼs usual countdown. i.e. changes from 90 to 80 in a second. | ||
| FaultStatus | Switch, Contact | accessory fault status. "ON"/"OPEN" value indicates that the accessory has experienced a fault that may be interfering with its intended functionality. A value of "OFF"/"CLOSED" indicates that there is no fault. | ||
| SecuritySystem | Security system. | |||
| CurrentSecuritySystemState | String | Current state of the security system. STAY_ARM / AWAY_ARM / NIGHT_ARM / DISARMED / TRIGGERED. Mapping can be redefined at item level, e.g. [AWAY_ARM="AWAY", NIGHT_ARM="NIGHT" ] | ||
| TargetSecuritySystemState | String | Requested state of the security system. STAY_ARM / AWAY_ARM / NIGHT_ARM / DISARM. While the requested state is not DISARM, and the current state is DISARMED, HomeKit will display "Arming...", for example during an exit delay. Mapping can be redefined at item level, e.g. [AWAY_ARM="AWAY", NIGHT_ARM="NIGHT" ] | ||
| Name | String | Name of the security system | ||
| TamperedStatus | Switch, Contact | accessory tampered status. A status of "ON"/"OPEN" indicates that the accessory has been tampered with. Value should return to "OFF"/"CLOSED" when the accessory has been reset to a non-tampered state. | ||
| GarageDoorOpener | A garage door opener. | |||
| ObstructionStatus | Switch | Current status of obstruction sensor. ON-obstruction detected, OFF - no obstruction | ||
| CurrentDoorState | String | Current door state. Possible values: OPEN, OPENING, CLOSED, CLOSING, STOPPED | ||
| TargetDoorState | Switch, String | Target door state. ON/"OPEN" = open door, OFF/"CLOSED" = closed door | ||
| Name | String | Name of the garage door | ||
| LockCurrentState | Switch | current states of lock mechanism (OFF=SECURED, ON=UNSECURED) | ||
| LockTargetState | Switch | target states of lock mechanism (OFF=SECURED, ON=UNSECURED) |
# Legacy tags
Following tags are still supported but could be removed in the future releases. Please consider replacing them with the new style.
| Old (tag style) | New (metadata style) |
| homekit:HeatingCoolingMode | CurrentHeatingCoolingMode |
| homekit:TargetHeatingCoolingMode | TargetHeatingCoolingMode |
| homekit:TargetTemperature | TargetTemperature |
| homekit:BatteryLowStatus | BatteryLowStatus |
| homekit:BatteryLevel | mapping to BatteryLowStatus |
| CurrentHumidity | RelativeHumidity |
| Blinds | WindowCovering |
| DimmableLighting | Lighting with characteristic Brightness |
| ColorfulLighting | Lighting with characteristic Brightness and Hue |
# Using "tag"
Color legacy_color_light_single "Legacy Color Light Single" [ "Lighting" ]
Color legacy_color_light_dimmable "Legacy Color Light Dimmable" [ "DimmableLighting" ]
Color legacy_color_light_hue "Legacy Color Light Hue" [ "ColorfulLighting" ]
Rollershutter legacy_window_covering "Legacy Window Rollershutter" [ "WindowCovering" ]
Switch legacy_switch_single "Legacy Switch single" [ "Switchable" ]
Switch legacy_contactsensor_single "Legacy Contact Sensor single" [ "ContactSensor" ]
Switch legacy_leaksensor_single "Legacy Leak Sensor single" [ "LeakSensor" ]
Switch legacy_leaksensor_single2 "Legacy Leak Sensor single 2" [ "LeakSensor", "LeakSensor.LeakDetectedState" ]
Switch legacy_motionsensor_single "Legacy Motion Sensor" [ "MotionSensor" ]
Switch legacy_occupancy_single "Legacy Occupanncy Sensor" [ "OccupancySensor" ]
Switch legacy_smoke_single "Legacy Smoke Sensor" [ "SmokeSensor" ]
Number legacy_humidity_single "Legacy Humidity Sensor" [ "CurrentHumidity" ]
Number legacy_temperature_sensor "Temperature Sensor" ["TemperatureSensor"]
Switch legacy_lock "Legacy Lock single" [ "Lock" ]
Switch legacy_valve_single "Legacy Valve Single" [ "Valve" ]
Group gLegacy_Valve "Legacy Valve Group" [ "Valve" ]
Switch legacy_valve_active "Legacy Valve active" (gLegacy_Valve) [ "Active" ]
Number legacy_valve_duration "Legacy Valve duration" (gLegacy_Valve) [ "Duration" ]
Number legacy_valve_remaining_duration "Legacy Valve remaining duration" (gLegacy_Valve) [ "RemainingDuration" ]
Group gLegacy_Thermo "Legacy Thermostat" [ "Thermostat" ]
Number legacy_thermostat_current_temp "L Therm. Cur. Temp. [%.1f C]" (gLegacy_Thermo) [ "CurrentTemperature" ]
Number legacy_thermostat_target_temp "L Therm. Target Temp.[%.1f C]" (gLegacy_Thermo) [ "homekit:TargetTemperature" ]
String legacy_thermostat_current_mode "Legacy Thermostat Current Mode" (gLegacy_Thermo) [ "homekit:CurrentHeatingCoolingMode" ]
String legacy_thermostat_target_mode "Thermostat Target Mode" (gLegacy_Thermo) [ "homekit:TargetHeatingCoolingMode" ]
Group gLegacy_Leaksensor "Legacy Leak Sensor Group" [ "LeakSensor" ]
Switch legacy_leaksensor "Legacy Leak Sensor" (gLegacy_Leaksensor) [ "LeakSensor" ]
Switch legacy_leaksensor_bat "Legacy Leak sensor battery status" (gLegacy_Leaksensor) [ "homekit:BatteryLowStatus" ]
Switch legacy_leaksensor_fault "Legacy Leak sensor fault" (gLegacy_Leaksensor) [ "FaultStatus" ]
Group gLegacy_Security "Legacy Security System Group" [ "SecuritySystem" ]
String legacy_SecurityCurrentState "Security Current State" (gLegacy_Security) [ "CurrentSecuritySystemState" ]
String legacy_SecurityTargetState "Security Target State" (gLegacy_Security) [ "TargetSecuritySystemState" ]
# Using "metadata"
Number temperature_sensor "Temperature Sensor [%.1f C]" {homekit="TemperatureSensor" [minValue=10.5, maxValue=27] }
Number thermostat_current_temp "Thermostat Current Temp [%.1f C]" (gThermostat) {homekit="Thermostat.CurrentTemperature" [minValue=0, maxValue=40]}
Number thermostat_target_temp "Thermostat Target Temp[%.1f C]" (gThermostat) {homekit="Thermostat.TargetTemperature" [minValue=10.5, maxValue=27]}
Number cooler_current_temp "Cooler Current Temp [%.1f C]" (gCooler) {homekit="CurrentTemperature"}
Number cooler_cool_thrs "Cooler Cool Threshold Temp [%.1f C]" (gCooler) {homekit="CoolingThresholdTemperature" [minValue=10.5, maxValue=50]}
Number cooler_heat_thrs "Cooler Heat Threshold Temp [%.1f C]" (gCooler) {homekit="HeatingThresholdTemperature" [minValue=0.5, maxValue=20]}
# Dimmers
The way HomeKit handles dimmer devices can be different to the actual dimmers' way of working. HomeKit home app sends following commands/update:
- On brightness change home app sends "ON" event along with target brightness, e.g. "Brightness = 50%" + "State = ON".
- On "ON" event home app sends "ON" along with brightness 100%, i.e. "Brightness = 100%" + "State = ON"
- On "OFF" event home app sends "OFF" without brightness information.
- OPEN if position is 0%,
- CLOSED if position is 100%.
- OPEN if position 100%
- CLOSED if position is 0%
Therefore, HomeKit integration inverts by default the values between openHAB and HomeKit, e.g. if openHAB current position is 30% then it will send 70% to HomeKit app. In case you need to disable this logic you can do it with configuration parameter inverted="false", e.g.
Rollershutter window_covering "Window Rollershutter" {homekit = "WindowCovering" [inverted="false"]}
Rollershutter window "Window" {homekit = "Window" [inverted="false"]}
Rollershutter door "Door" {homekit = "Door" [inverted="false"]}
Rollershutter window_covering "Blind" (gBlind) {homekit = "WindowCovering"}
Dimmer window_covering_htilt "Blind horizontal tilt" (gBlind) {homekit = "WindowCovering.CurrentHorizontalTiltAngle, WindowCovering.TargetHorizontalTiltAngle"}
Dimmer window_covering_vtilt "Blind vertical tilt" (gBlind) {homekit = "WindowCovering.CurrentVerticalTiltAngle, WindowCovering.TargetVerticalTiltAngle"}
# Valve
Upon valve activation in home app, home app starts to count down from the "duration" to "0" without contacting the server. Home app also does not trigger any action if it remaining duration get 0. It is up to valve to have an own timer and stop valve once the timer is over. Some valves have such timer, e.g. pretty common for sprinklers. In case the valve has no timer capability, openHAB can take care on this - start an internal timer and send "Off" command to the valve once the timer is over.
- valve with timer:
Group gValve "Valve Group" {homekit="Valve" [homekitValveType="Irrigation", homekitTimer="true]}
# Sensors
| BatteryLowStatus | Switch, Contact | Accessory battery status. "ON"/"OPEN" indicates that the battery level of the accessory is low. Value should return to "OFF"/"CLOSED" when the battery charges to a level thats above the low threshold. |
Number temperature_sensor "Temperature Sensor [%.1f C]" {homekit="TemperatureSensor"}
Switch motionsensor_bat "Motion Sensor Battery" (gMotionSensor) {homekit="BatteryLowStatus"}
# Common Problems
openHAB HomeKit hub shows up when I manually scan for devices, but Home app reports "can't connect to device"
If you see this error in the Home app, and don't see any log messages, it could be because your IP address in the networkInterface setting is misconfigured.
The openHAB HomeKit hub is advertised via mDNS.
If you register an IP address that isn't reachable from your phone (such as localhost, 0.0.0.0, 127.0.0.1, etc.), then Home will be unable to reach openHAB.
# Additional Notes
To do this, you can issue the command smarthome:homekit clearPairings from the OSGi console (opens new window).
# Console commands
smarthome:homekit list - list all HomeKit accessories currently advertised to the HomeKit clients.
smarthome:homekit show <accessory_id | name> - print additional details of the accessories which partially match provided ID or name.
