Runtime Commands
Examples
Query an item's state:
Changing an item's state:
Get help for a command:
Items
| Command | Description |
smarthome:status <item> | shows the current status of an item |
smarthome:update <item> <state> | sends a status update for an item |
smarthome:send <item> <command> | sends a command for an item |
smarthome:items list [<pattern>] | lists names and types of all items (matching the pattern, if given) |
smarthome:items clear | removes all items |
smarthome:items remove <itemName> | removes the given item |
Discovery
smarthome:discovery start <thingTypeUID!bindingID> | runs a discovery on a given thing type or binding |
smarthome:discovery enableBackgroundDiscovery <PID> | enables background discovery for the discovery service with the given PID |
smarthome:discovery disableBackgroundDiscovery <PID> | disables background discovery for the discovery service with the given PID |
Inbox
smarthome:inbox | lists all current inbox entries |
smarthome:inbox listignored | lists all ignored inbox entries |
smarthome:inbox approve <thingUID> <label> | creates a thing for an inbox entry |
smarthome:inbox clear | clears all current inbox entries |
smarthome:inbox ignore <thingUID> | ignores an inbox entry permanently |
Things
smarthome:things list | lists all things |
smarthome:things clear | removes all managed things |
Links
smarthome:links list | lists all links |
smarthome:links addChannelLink <itemName> <channelUID> | links an item with a channel |
smarthome:links removeChannelLink <itemName> <thingUID> | unlinks an item with a channel |
smarthome:links clear | removes all managed links |
Audio
smarthome:audio play [<sink>] <filename> | plays a sound file from the $OPENHAB_CONF/sounds folder through the optionally specified audio sink(s) |
smarthome:audio play <sink> <filename> <volume> | plays a sound file from the $OPENHAB_CONF/sounds folder through the specified audio sink(s) with the specified volume |
smarthome:audio stream [<sink>] <url> | streams the sound from the url through the optionally specified audio sink(s) |
smarthome:audio sources | lists the audio sources |
smarthome:audio sinks | lists the audio sinks |
Voice
smarthome:voice say <text> | speaks a text on the default audio sink with the default TTS and voice |
smarthome:voice voices | lists available voices of the active TTS services |
smarthome:voice interpret <command> | interprets a human language command |
Automation
smarthome:script <script to execute> | Executes a script from the $OPENHAB_CONF/scripts folder |
Firmware
smarthome:firmware list <thingTypeUID> | Lists the available firmwares for a thing type. |
smarthome:firmware status <thingUID> | lists the firmware status for a thing |
smarthome:firmware update <thingUID> <firmware version> | updates the firmware for a thing |
