# openHAB 2 on Windows
The following instructions will guide you through the process of setting up openHAB 2.
# Prerequisites
First, be sure to check that your system has the necessary prerequisites.
Add the JAVA_HOME
System Environment Variable in Windows.
Navigate to:
- Control Panel ➡️ System and Security ➡️ System ➡️ Advanced System Settings ➡️ Environment Variables ➡️ System Variables
Create a New System Variable based on your Java installation directory:
The directory that openHAB is installed to must contain no spaces.
On this page, we will be using C:\openHAB2
as an example.
# Installation
Download the latest Windows Stable or Snapshot ZIP archive file for manual installation from the Download (opens new window) page.
Unzip the file in your chosen directory (e.g.
C:\openHAB2
)Start the server: Launch the runtime by executing the script
C:\openHAB2\start.bat
and wait a while for it to start and complete.Point your browser to
http://localhost:8080
. You should be looking at the openHAB package selection page. When you've selected an appropriate package, this page will contain the UI selection screen, see here for example.
# File Locations
Assuming a successful install, you will now have various folders inside C:\openHAB2
Windows Installation | |
openHAB application | C:\openHAB2\runtime |
Additional add-on files | C:\openHAB2\addons |
Site configuration | C:\openHAB2\conf |
Log files | C:\openHAB2\userdata\logs |
Userdata like rrd4j databases | C:\openHAB2\userdata |
Service configuration | C:\openHAB2\userdata\etc |
# Backup
Make sure that you make regular backups of the conf and userdata folders, you can zip and unzip these folders too and from openHAB installations (even across most versions).
When you have a setup that you are happy with, it would be a good idea to make a backup of the whole C:\openHAB2
folder.
Which can be used any time after a failure.
To start the update process, run PowerShell as an administrator and use the following commands, while replacing x.x.x
with the wanted openHAB version.
Assuming you have openHAB installed in C:\openHAB2
cd C:\openHAB2
. .\runtime\bin\update.ps1
# Starting openHAB as a Service
- Launch it automatically upon system startup
- Run it in the background
Windows Service Installation Steps
Complete the prerequisites and regular installation steps, including the package selection
Issue the following two commands in your openHAB console:
feature:install service-wrapper wrapper:install --name "openHAB2" --display "openHAB2" --description "openHAB 2 Service"
Shutdown the openHAB instance by typing
logout
in the currently running console.Update the newly created
C:\openHAB2\userdata\etc\openHAB2-wrapper.conf
to include all necessary parameters.- Copy all the config text from the below section and paste it in your
, replacing all existing content. - Adapt the first entry (
OPENHAB_HOME
) to match your openHAB installation directory.
#******************************************************* # openHAB2-wrapper.conf for Windows Service Installation #******************************************************* # openHAB installation dir (Adapt this first setting to your system) set.default.OPENHAB_HOME=C:\openHAB2 # Wrapper Properties set.default.OPENHAB_CONF=%OPENHAB_HOME%\conf set.default.OPENHAB_RUNTIME=%OPENHAB_HOME%\runtime set.default.OPENHAB_USERDATA=%OPENHAB_HOME%\userdata set.default.OPENHAB_LOGDIR=%OPENHAB_USERDATA%\logs set.default.KARAF_HOME=%OPENHAB_RUNTIME% set.default.KARAF_BASE=%OPENHAB_USERDATA% set.default.KARAF_DATA=%OPENHAB_USERDATA% set.default.KARAF_ETC=%OPENHAB_USERDATA%\etc set.default.PATH=%PATH%;%KARAF_BASE%\lib;%KARAF_HOME%\lib # Java Application wrapper.working.dir=%KARAF_BASE% wrapper.java.command=%JAVA_HOME%\bin\java wrapper.java.mainclass=org.apache.karaf.wrapper.internal.service.Main wrapper.java.classpath.1=%KARAF_HOME%\lib\boot\*.jar wrapper.java.classpath.2=%KARAF_DATA%\lib\wrapper\*.jar wrapper.java.library.path.1=%KARAF_DATA%\lib\wrapper\ # Java Parameters wrapper.java.additional.1=-Dkaraf.home="%KARAF_HOME%" wrapper.java.additional.2=-Dkaraf.base="%KARAF_BASE%" wrapper.java.additional.3=-Dkaraf.data="%KARAF_DATA%" wrapper.java.additional.4=-Dkaraf.etc="%KARAF_ETC%" wrapper.java.additional.5=-Dcom.sun.management.jmxremote wrapper.java.additional.6=-Dkaraf.startLocalConsole=false wrapper.java.additional.7=-Dkaraf.startRemoteShell=true wrapper.java.additional.8=-Djava.endorsed.dirs="%JAVA_HOME%\jre\lib\endorsed;%JAVA_HOME%\lib\endorsed;%KARAF_HOME%\lib\endorsed" wrapper.java.additional.9=-Djava.ext.dirs="%JAVA_HOME%\jre\lib\ext;%JAVA_HOME%\lib\ext;%KARAF_HOME%\lib\ext" wrapper.java.additional.10=-Dopenhab.home="%OPENHAB_HOME%" wrapper.java.additional.11=-Dopenhab.conf="%OPENHAB_HOME%\conf" wrapper.java.additional.12=-Dopenhab.runtime="%OPENHAB_HOME%\runtime" wrapper.java.additional.13=-Dopenhab.userdata="%OPENHAB_HOME%\userdata" wrapper.java.additional.14=-Dopenhab.logdir="%OPENHAB_USERDATA%\logs" wrapper.java.additional.15=-Dfelix.cm.dir="%OPENHAB_HOME%\userdata\config" wrapper.java.additional.16=-Dorg.osgi.service.http.port=8080 wrapper.java.additional.17=-Dorg.osgi.service.http.port.secure=8443 wrapper.java.additional.18=-Djava.util.logging.config.file="%KARAF_ETC%\java.util.logging.properties" wrapper.java.additional.19=-Dkaraf.logs="%OPENHAB_LOGDIR%" wrapper.java.additional.20=-Dfile.encoding=UTF-8 wrapper.java.maxmemory=512 # Wrapper Logging Properties wrapper.console.format=PM wrapper.console.loglevel=INFO wrapper.logfile=%OPENHAB_USERDATA%\logs\wrapper.log wrapper.logfile.format=LPTM wrapper.logfile.loglevel=INFO wrapper.logfile.maxsize=10m wrapper.logfile.maxfiles=5 wrapper.syslog.loglevel=NONE # Wrapper Windows Properties wrapper.console.title=openHAB2 wrapper.ntservice.name=openHAB2 wrapper.ntservice.displayname=openHAB2 wrapper.ntservice.description=openHAB 2 Service wrapper.ntservice.dependency.1= wrapper.ntservice.starttype=AUTO_START wrapper.ntservice.interactive=false
Open an elevated command prompt and type the following commands:
C:\openHAB2\userdata\bin\openHAB2-service.bat install net start "openHAB2"
Your openHAB Windows service is now installed and running. Validate proper operations by:
Browsing to http://localhost:8080 (opens new window)
Verifying that the Windows Service is running and set to Automatic Startup type. Use
services.msc
and find theopenHAB2
service.Logging in with an SSH client to the console (see info below)
You can connect to openHAB's console using the the C:\openHAB2\runtime\bin\client.bat
script on the local machine.
Alternatively, you can use a standard SSH client:
Install an SSH client application, e.g., Putty (opens new window), KiTTY (opens new window) or Xshell 5 (opens new window)
Setup a session with the following parameters:
- Host: 127.0.0.1
- Port: 8101
- Username:
openhab
- Password:
habopen
