# openHAB 2 on Linux
The following instructions will guide you through the process of setting up openHAB 2 and recommended packages for both .DEB (Ubuntu, Debian etc.) and .RPM (RedHat, CentOS, Fedora etc.) Linux systems.
If you find yourself in a situation, where you have no write access to the openHAB configuration or system files wrong permissions and/or the incorrect use of sudo are often the cause.
# Meeting the Requirements:
As a first step, please verify, that your system meets the prerequisites. You may want to install Zulu, a fully certified Java build as a package (opens new window) or manually (opens new window).
If you're unsure which manual file you should download, using dpkg --print-architecture or rpm -q --qf '%{ARCH}\n' rpm in your Linux terminal should point you in the right direction (e.g. armhf means ARM Hard Float).
Make sure to download Zulu or Java 8, as openHAB is not yet compatible with Java 9.
# Installation
openHAB 2 can be installed through
- manually from file.
# openHABian project
# Apt Based Systems
First, add the openHAB repository key to your package manager and allow Apt to use the HTTPS Protocol:
wget -qO - 'https://openhab.jfrog.io/artifactory/api/gpg/key/public' | sudo apt-key add -
sudo apt-get install apt-transport-https
Stable Release
Add the openHAB 2 Stable Repository to your systems apt sources list:
echo 'deb https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable main' | sudo tee /etc/apt/sources.list.d/openhab2.listTesting Release
The beta and release candidate builds come out less frequently, but will contain new features that are currently in the testing phase.
Add the openHAB 2 Beta Repository to your systems apt sources list:
echo 'deb https://openhab.jfrog.io/openhab/openhab-linuxpkg testing main' | sudo tee /etc/apt/sources.list.d/openhab2.listSnapshot Release
The snapshot build is created almost daily (opens new window), and include the latest changes to the openHAB 2 core and add-ons. These changes are often unstable, so you should use this branch only for testing or development purposes.
The snapshot repository is hosted in openHAB's JFrog Artifactory instance (opens new window). To use it, add the openHAB 2 Unstable Repository to your systems apt sources list:
echo 'deb https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable main' | sudo tee /etc/apt/sources.list.d/openhab2.list
sudo apt-get update
sudo apt-get install openhab2
sudo apt-get install openhab2-addons
# Yum or Dnf Based Systems
The RPM repo information should be defined inside a file, make a new file at /etc/yum.repos.d/openhab.repo with the following contents depending on your choice of release.
You may add all three to the same file, but make sure the desired repo is is set to enabled=1:
Stable Release
[openHAB-Stable] name=openHAB Stable baseurl=https://openhab.jfrog.io/artifactory/openhab-linuxpkg-rpm/stable gpgcheck=1 gpgkey=https://openhab.jfrog.io/artifactory/api/gpg/key/public enabled=1Testing Release
[openHAB-Testing] name=openHAB 2.x.x Testing baseurl=https://openhab.jfrog.io/openhab/openhab-linuxpkg-rpm/testing gpgcheck=1 gpgkey=https://openhab.jfrog.io/artifactory/api/gpg/key/public enabled=1Snapshot Release
[openHAB-Snapshots] name=openHAB 2.x.x Snapshots baseurl=https://openhab.jfrog.io/openhab/openhab-linuxpkg-rpm/unstable gpgcheck=1 gpgkey=https://openhab.jfrog.io/artifactory/api/gpg/key/public enabled=1
sudo yum install openhab2
sudo yum install openhab2-addons
Optionally, you may in addition install the legacy add-ons package openhab2-addons-legacy.
This package contains 1.x bindings, for which there is already a 2.x version available.
This might be useful if you're coming from openHAB 1.x for example.
sudo /etc/init.d/openhab2 start
sudo /etc/init.d/openhab2 status
sudo update-rc.d openhab2 defaults
sudo systemctl start openhab2.service
sudo systemctl status openhab2.service
sudo systemctl daemon-reload
sudo systemctl enable openhab2.service
You should be able to reach the openHAB 2 Dashboard at http://openhab-device:8080 at this point. If you're new to openHAB, then you should checkout the beginner's tutorial!
# Service Control
sudo /etc/init.d/openhab2 restart
sudo /etc/init.d/openhab2 stop
sudo systemctl restart openhab2.service
sudo systemctl stop openhab2.service
sudo journalctl -u openhab2.service -b
After installing openHAB, a shortcut named openhab-cli provides access to the openHAB-specific commands (such as backup, restore, and console).
To use the shortcuts in a terminal, simply type openhab-cli followed by the command.
For example:
Usage: openhab-cli command [options]
Possible commands:
start [--debug] -- Starts openHAB in the terminal.
stop -- Stops any running instance of openHAB.
status -- Checks to see if openHAB is running.
console -- Opens the openHAB console.
backup [filename] -- Stores the current configuration of openHAB.
restore filename -- Restores the openHAB configuration from a backup.
showlogs -- Displays the log messages of openHAB.
info -- Displays distribution information.
# Changing Versions
# Apt Based Systems
Upgrading is as easy as:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get update
apt-cache showpkg openhab2
Once you know which version you want, you can upgrade/downgrade to it by using the apt-get install openhab2=[version] command, for example:
sudo apt-get install openhab2=2.1.0-1
sudo yum upgrade
rpm -q openhab2
Once you know which version you want, you can upgrade/downgrade to it by using the yum install openhab2-[version] command, for example:
sudo yum install openhab2-2.1.0-1
# Uninstall
To uninstall openHAB 2 and get rid of all related files managed by the package manager, make a backup, then uninstall openHAB and remove the repository:
# Apt Based Systems
sudo apt-get purge openhab2*
sudo rm /etc/apt/sources.list.d/openhab2.list
sudo yum remove openhab2*
sudo rm /etc/yum.repos.d/openHAB.repo
# Manual Installation
We are going to download a platform independent archive file and extract it to the path /opt/openhab2.
As openHAB 2 is still in an evolving state, the snapshot may be the preferred choice.
Official Release
Download and extract the latest offical stable version of openHAB 2 from our downloadpage (opens new window) to your host:
cd /tmp wget -O openhab-download.zip https://www.openhab.org/download/releases... # Insert download link here sudo unzip openhab-download.zip -d /opt/openhab rm openhab-download.zipBeta/RC Release
If available, beta or release candidate builds of openHAB 2 can also be downloaded from our downloadpage (opens new window) and extracted to your host as shown above.
Snapshot Release
Download and extract the latest snapshot version of openHAB 2 from our downloadpage (opens new window) to your host. The process is analogue to above.
The extracted openHAB files should belong to the earlier created openhab user.
Execute:
sudo chown -hR openhab:openhab /opt/openhab2
Everything is ready for a first test run. Execute openHAB and you should be able to reach the openHAB 2 Dashboard at http://openhab-device:8080 after a few minutes:
sudo su -s /bin/bash -c '/opt/openhab2/start.sh' openhab
You will see the openHAB Console in your terminal and can directly interact with it. Please be aware, that openHAB 2 will need a few minutes so finish the first start, even after the openHAB console is visible. Let openHAB 2 settle for around 15 minutes. If the portal is not reachable by then, restart once.
# Service
The service will be running with the privileges of the user "openhab" and expects the openHAB files under /opt/openhab2.
Create the file /usr/lib/systemd/system/openhab2.service with the following content:
[Unit]
Description=openHAB 2 - empowering the smart home
Wants=network-online.target
After=network-online.target
[Service]
User=openhab
Group=openhab
WorkingDirectory=/opt/openhab2
#EnvironmentFile=-/etc/default/openhab2
ExecStart=/opt/openhab2/runtime/bin/karaf daemon
ExecStop=/opt/openhab2/runtime/bin/karaf stop
Restart=on-failure
SuccessExitStatus=0 143
[Install]
WantedBy=multi-user.target
#start and retrieve status
openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
# Installing add-ons
Simply download the kar files (the latest builds can be found here (opens new window)) and move them to the /opt/openhab2/addons folder.
# Upgrade
Versions 2.1.0 and Above
From version 2.1.0, openHAB is distributed with the update script included. This script should be called from within openHAB's root directory. Assuming the openHAB directory is in
/opt/openhab, simply run the following commands to update to the next major version of openHAB:cd /opt/openhab sudo runtime/bin/updateYou can also specify any version as a parameter. For example, to switch back to 2.0.0:
sudo runtime/bin/update 2.0.0You may also change to openHAB's more frequent, but less stable snapshot builds. Just append "-SNAPSHOT" to the target version, e.g.:
sudo runtime/bin/update 2.2.0-SNAPSHOTOlder Versions
If you're using a version earlier than 2.1.0, then you can use the following commands in Terminal to download the script and run it. Assuming the openHAB directory is in
/opt/openhab:cd /opt/openhab sudo sh -c "$(curl -fsSL https://raw.githubusercontent.com/openhab/openhab-distro/master/distributions/openhab/src/main/resources/bin/update)" -- 2.1.0
# Uninstall
To uninstall (or more precisely remove) openHAB 2 after being manually set up, take a backup if needed and then simply stop and deactivate the openHAB service and get rid of all files:
sudo systemctl disable openhab2.service
sudo rm -rf /opt/openhab2/
sudo rm /usr/lib/systemd/system/openhab2.service
sudo rm /lib/systemd/system/openhab2.service
# File Locations
| Repository Installation | Manual Installation (according to guide) | |
| openHAB application | /usr/share/openhab2 | /opt/openhab2 |
| Additional add-on files | /usr/share/openhab2/addons | /opt/openhab2/addons |
| Site configuration | /etc/openhab2 | /opt/openhab2/conf |
| Log files | /var/log/openhab2 | /opt/openhab2/userdata/logs |
| Userdata like rrd4j databases | /var/lib/openhab2 | /opt/openhab2/userdata |
| Backups folder | /var/lib/openhab2/backups | /opt/openhab2/backups |
| Service configuration | /etc/default/openhab2 | (not preconfigured) |
# Backup and Restore
To make a backup of openHAB2, you need to retain your configuration and userdata files.
openHAB comes with scripts for storing your configuration in a zip file which is saved in /var/lib/openhab2/backups for automatic installs and openhab2/backups for manual installs.
## OR ##
# Viewing Log Messages
Package repository based installation:
tail -f /var/log/openhab2/openhab.log -f /var/log/openhab2/events.logManual installation:
tail -f /opt/openhab2/userdata/logs/openhab.log -f /opt/openhab2/userdata/logs/events.log
With openHAB 2 you can also use the openHAB console to have a colored glance at the logging information.
The following is not directly related to the openHAB installation but rather recommended on a openHAB system. The need for these and the exact implementation on a specific system might differ from user to user.
The following example shows how to add Linux user openhab to the often needed groups dialout and tty.
sudo adduser openhab dialout
sudo adduser openhab tty
sudo adduser openhab audio
Additionally it's needed to allow the java environment to access the serial port of the connected peripheral.
Therefore the following setting has to be added/adapted on your system in file /etc/default/openhab2:
EXTRA_JAVA_OPTS="-Dgnu.io.rxtx.SerialPorts=/dev/ttyUSB0:/dev/ttyS0:/dev/ttyS2:/dev/ttyACM0:/dev/ttyAMA0"
The shown device handlers are just the most common examples. Please contact the community forum for more detailed information regarding individual hardware.
# Java Network Permissions
The Java Virtual Machine hosting openHAB is restricted in its permissions to interact on network level for security reasons. Some openHAB add-ons, like the Network or AmazonDash bindings, need elevated permissions to work. If needed, grand these permissions by executing the following command:
# Network Sharing
sudo vim /etc/samba/smb.conf
wins support = yes
[openHAB2-userdata] comment=openHAB2 userdata path=/var/lib/openhab2 browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777 [openHAB2-conf] comment=openHAB2 site configuration path=/etc/openhab2 browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777 [openHAB2-logs] comment=openHAB2 logs path=/var/log/openhab2 browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777Manual installation:
[openHAB-files] comment=openHAB2 path=/opt/openhab2 browseable=Yes writeable=Yes only guest=no public=no create mask=0777 directory mask=0777
sudo smbpasswd -a openhab
sudo chown -hR openhab:openhab /etc/openhab2 /opt/openhab2/conf
testparm
sudo service smbd restart
# Mounting Locally
- On macOS: Open Finder → Go → Connect to Server:
smb://[email protected] - On Windows: Open Windows Explorer → Address bar:
\\openhab-device.local→ Right click a share and assign a drive letter
Be sure to use the actual host name instead of openhab-device.
If you are not able to connect, try with the IP of your device (e.g. smb://[email protected] or \\192.168.0.2).
