# Developing a Binding
- Structure of a Binding
- Describing Things
- The ThingHandlerFactory
- The ThingHandler
- Updating the Thing from a Binding
- Bridges
- Config Status Provider
- Handling Thing / Bridge Removal
- Actions bound to a Thing
- Firmware information / Firmware update
- Implementing a Discovery Service
- Frequently asked questions / FAQ
- Include the Binding in the Build
# Structure of a Binding
Every binding needs to define a binding.xml file.
Find more information in the respective binding XML reference.
# Describing Things
# The ThingHandlerFactory
@NonNullByDefault
@Override
@Override
return null;
# The ThingHandler
If the framework wants the binding to do something or just notfiy it about changes,
The BaseThingHandler provides convience methods like updateState, updateStatus updateThing or triggerChannel, that can be used to inform the framework about changes.
TODO
# Lifecycle
# Startup
Handler is registered:
ThingHandlerinstance is created by aThingHandlerFactoryand tracked by the framework. In addition, the handler can be registered as a service if required, e.g. asFirmwareUpdateHandlerorConfigStatusProvider.Handler is initialized:
ThingHandler.initialize()is called by the framework in order to initialize the handler. This method is only called if all 'required' configuration parameters of the Thing are present. The handler is ready to work (methods likehandleCommand,handleUpdateorthingUpdatedcan be called).
The diagram below illustrates the startup of a handler in more detail.
The life cycle is controlled by the ThingManager.
# Shutdown
Handler is unregistered:
ThingHandlerinstance is no longer tracked by the framework. TheThingHandlerFactorycan unregister handler services (e.g.FirmwareUpdateHandlerorConfigStatusProvider) if registered, or release resources.Handler is disposed:
ThingHandler.disposed()method is called. The framework expectsdispose()to be non-blocking and to return quickly. For longer running disposals, the implementation has to take care of scheduling a separate job.
# Bridge Status Changes
Only the following types are supported for configuration values: Boolean, String and BigDecimal.
For example, the Yahoo Weather binding allows configuration of the location and the refresh frequency.
# Properties
Things can have properties. If you would like to add meta data to your thing, e.g. the vendor of the thing, then you can define your own thing properties by simply adding them to the thing type definition. The properties section here explains how to specify such properties.
To retrieve the properties one can call the operation getProperties of the corresponding org.eclipse.smarthome.core.thing.type.ThingType instance.
Therefore the org.eclipse.smarthome.core.thing.Thing interface also provides the getProperties operation to retrieve the defined properties.
# Handling Commands
@Override
try {
switch (channelUID.getId()) {
case CHANNEL_TEMPERATURE:
break;
@Override
updateWeatherData();
break;
case CHANNEL_HUMIDITY:
# Updating the Channel State
# Polling for a State
@Override
public void initialize() {
Runnable runnable = new Runnable() {
@Override
public void run() {
pollingJob = scheduler.scheduleAtFixedDelay(runnable, 0, 30, TimeUnit.SECONDS);
@Override
public void dispose() {
pollingJob.cancel(true);
# Trigger a channel
triggerChannel("channelId")
# Updating the Thing Status
At this time the state of the thing is INTIALIZING as long as the binding sets it to something else.
# Channel Links
# Updating the Configuration
# Updating Thing Properties
updateProperties(properties);
# Handling Thing Updates
@Override
dispose();
this.thing = thing;
initialize();
# Bridges
We have a FAQ, dicussing Thing, Bridge and Channel modelling.
@Override
break;
case CHANNEL_ID_COLOR:
A BridgeHandler handles the communication between the openHAB framework and a bridge (a device that acts as a gateway to enable the communication with other devices) represented by a Bridge instance.
# The BaseBridgeHandler
# Life cycle
- A
BridgeHandlerof a bridge is initialized beforeThingHandlers of its child things are initialized. - A
BridgeHandleris disposed after allThingHandlers of its child things are disposed.
# Config Status Provider
For this purpose the handler of the entity implements the interface org.eclipse.smarthome.config.core.status.ConfigStatusProvider.
A ThingHandler as handler for the thing entity can provide the configuration status of the thing by implementing the org.eclipse.smarthome.config.core.status.ConfigStatusProvider interface.
org.eclipse.smarthome.core.thing.binding.ConfigStatusThingHandlerextends theBaseThingHandlerand is to be used if the configuration status is to be provided for thing entitiesorg.eclipse.smarthome.core.thing.binding.ConfigStatusBridgeHandlerextends theBaseBridgeHandlerand is to be used if the configuration status is to be provided for bridge entities
Sub-classes of these handlers must only override the operation getConfigStatus to provide the configuration status in form of a collection of org.eclipse.smarthome.config.core.status.ConfigStatusMessages.
# Internationalization
After the removal was requested (i.e. the thing is in REMOVING state), it cannot be changed back anymore to ONLINE/OFFLINE/UNKNOWN by the binding.
# Actions bound to a Thing
Examples are:
- Reboot / Restart device
You start things off by implementing ThingActions and annotate your class with @ThingActionsScope:
@NonNullByDefault
@Override
@Override
@Override
return Collections.singleton(MQTTActions.class);
In the following example we provide a "publishMQTT" action.
An action must be annotated with @RuleAction, a label and a description must be provided.
public void publishMQTT(
Each parameter of an action member method must be annotated with @ActionInput.
If you return values, you do so by returning a Map<String,Object> and annotate the method itself with as many @ActionOutputs as you will return map entries.
TODO
| Field | Description |
thingUID | The thingUID is the unique identifier of the specific discovered thing (e.g. a device's serial number). It must not be constructed out of properties, that can change (e.g. IP addresses). A typical thingUID could look like this: hue:bridge:001788141f1a |
thingTypeUID | Contrary to the thingUID is the thingTypeUID that specifies the type the discovered thing belongs to. It could be constructed from e.g. a product number. A typical thingTypeUID could be the following: hue:bridge. |
bridgeUID | If the discovered thing belongs to a bridge, the bridgeUID contains the UID of that bridge. |
properties | The properties of a DiscoveryResult contain the configuration for the newly created thing. |
label | The human readable representation of the discovery result. Do not put IP/MAC addresses or similar into the label but use the special representationProperty instead. |
representationProperty | The name of one of the properties or configuration parameters, which best discriminates the result from other results of the same type. See chapter Representation Property below. |
For UPnP and mDNS there already are generic discovery services available.
Bindings only need to implement a UpnpDiscoveryParticipant resp. mDNSDiscoveryParticipant.
For details refer to the chapters UPnP Discovery and mDNS Discovery.
if (thingUID != null) {
# Representation Property
.build();
.build();
public String uniqueId;
# Background Discovery
@Override
@Override
wemoDiscoveryJob = null;
# Active Scan
@Override
public void startScan() {
if (lights != null) {
for (FullLight l : lights) {
onLightAddedInternal(l);
// search for unpaired lights
# Ending an Active Scan
In particular UIs such as the Paper UI will show the scan as in progress throughout the timeout.
# Remove older results
@Override
super.stopScan();
Hint!
The devoloper has to take care about that.
# UPnP Discovery
Here the developer only needs to implement three simple methods:
getSupportedThingTypeUIDs- Returns the list of thing type UIDs that this participant supports. The discovery service uses this method of all registered discovery participants to return the list of currently supported thing type UIDs.getThingUID- Creates a thing UID out of the UPnP result or returnsnullif this is not possible. This method is called from the discovery service during result creation to provide a unique thing UID for the result.createResult- Creates theDiscoveryResultout of the UPnP result. This method is called from the discovery service to create the actual discovery result. It uses thegetThingUIDmethod to create the thing UID of the result.
@Override
return Collections.singleton(THING_TYPE_BRIDGE);
@Override
if (uid != null) {
return result;
return null;
@Override
if (details != null) {
if (modelDetails != null) {
if (modelName != null) {
return null;
# mDNS Discovery
getServiceType- Defines the mDNS service type (opens new window).getSupportedThingTypeUIDs- Returns the list of thing type UIDs that this participant supports. The discovery service uses this method of all registered discovery participants to return the list of currently supported thing type UIDs.getThingUID- Creates a thing UID out of the mDNS service info or returnsnullif this is not possible. This method is called from the discovery service during result creation to provide a unique thing UID for the result.createResult- Creates theDiscoveryResultout of the mDNS result. This method is called from the discovery service to create the actual discovery result. It uses thegetThingUIDmethod to create the thing UID of the result.
# Discovery that is bound to a Thing
Instead of using the Component annotation your discovery service implements the ThingHandlerService.
It should extend the AbstractDiscoveryService just like a normal service.
But you should also add the interface DiscoveryService to make sure the openHAB framework will register it as a discovery service:
public class <your binding bridge DiscoveryService> extends AbstractDiscoveryService
implements DiscoveryService, ThingHandlerService {
The interface ThingHandlerService has 2 methods to pass the handler of the bridge.
A typical implementation is:
@Override
if (handler instanceof <your binding handler>) {
bridgeHandler = (<your binding handler>) handler;
@Override
return bridgeHandler;
The setThingHandler is called by the openHAB framework and give you access to the binding bridge handler.
The handler can be used to get the bridge UID or to get access to the configured device connected to the bridge handler.
@Override
return Collections.singleton(<your binding bridge DiscoveryService>.class);
Various binding related questions are answered in our Binding development FAQ.
# Include the Binding in the Build
Once you are happy with your implementation, you need to integrate it in the Maven build and add it to the official distro.
- Add a new line in the bundle pom.xml (opens new window).
- Add a new line in the binding pom.xml (opens new window).
- If you have a dependency on a transport bundle (e.g. upnp, mdns or serial) or an external library,
make sure to add a line for this dependency in the
/src/main/feature/feature.xmlfile in your binding folder. See the other bindings as an example. - Add your binding to the CODEOWNERS (opens new window) file so that you get notified by Github when someone adds a pull request towards your binding.
Please make sure you add the above entries at their alphabetically correct position!
Before you create a pull request on GitHub, you should now run
mvn clean install
from the repository root to ensure that the build works smoothly (that step takes about 30 minutes).
The build includes Tooling for static code analysis (opens new window) that will validate your code against the openHAB Coding Guidelines and some additional best practices. Please fix all the priority 1 issues and all issues with priority 2 and 3 that are relevant (if you have any doubt don't hesitate to ask).
You can always run the above command from within your bindings directory to speed the build up and fix and check reported errors.
Re-run the build to confirm that the checks are passing. If it does, it is time to contribute your work!
