# Eclipse IDE
If you already have Eclipse installed it is recommended to perform a separate Eclipse install for OpenHAB to avoid overriding your existing Eclipse configuration.
# Eclipse IDE Setup
Install the Java 8 JDK if you did not have it installed.
Attention
openHAB development requires Java JDK version 8.
Download the "Eclipse Installer": can be downloaded from the Eclipse web site (opens new window)
Launch the Installer and on the menu on the top right (3 bars)
Select
ADVANCED MODE...
Select
Eclipse IDE for Java Developers
. SelectNext >
.Under
GitHub Projects > openHAB
selectopenHAB Development
and any desired option fromopenHAB Add-ons
(includes all add-ons from openhab-addons repo),openHAB ZigBee Binding
oropenHAB Z-Wave Binding
.Selection Install if Branches openHAB Development Debug/Demo Environment (Required) 2.5.x, 3.0 openHAB Add-ons Add-ons Development 2.5.x, 3.0 openHAB ZigBee Binding ZigBee Binding Development 2.5.x, 3.0 openHAB Z-Wave Binding Z-Wave Binding Development 2.5.x, 3.0 openHAB BACNet Binding BACNet Binding Development openHAB Web UIs Web UIs Development 2.5.x, 3.0 openHAB Core Framework Core Framework Development 3.0 Attention
Select
2.5.x
if you want to develop for 2.5.x. The Core Framework only has a master branch (3.0 development), which means you can no longer make Core Framework changes for a 2.5.x system.Click
Next>
, verify/modify Root and install folder name. Click onShow all variables
to open the window shown below.Explanation of some of the variables
Root install folder
: The base folder where theInstallation folder
will be placed.Installation folder name
: This is the directory in the root install folder everything will be installed in.GitHub user ID
: This is your GitHub user name used to configure the cloned Git projects.
Click
Next>
andFinish
to start installation.During install accept licence agreement, "Unsigned Content" for Bndtools, and Eclipse Foundation certificates when requested to complete IDE installation.
At this point the Eclipse installer is finished and the Eclipse IDE is automatically launched to continue the installation process.
Attention
Setup tasks will personalize the IDE with openHAB code formatting tools, configurations and a demo app. Setup tasks will also download openHAB latest projects you have selected during installation. Like
openhab-distro
and the add-onsopenhab-addons
project if you have selected it.Click bottom right button in the IDE for Progress.
After all tasks are finished you are ready to start developing.
If you need additional libraries see the Build System documentation. For other libraries supported out-of-the-box check the Default Libraries on the guidelines page.
# Working with Add-ons
To easily run, modify and debug an add-on the openHAB Development
setup installs and imports a demo project that contains a complete openHAB environment to run and debug an add-on.
This mechanism replaces the add-on installation process via the PaperUI that you would use outside the IDE.
# Running Add-ons
Under Infrastructure
you will find the project org.openhab.demo.app
This project contains the full configuration to run OpenHAB.
The following files are of interest for the execution environment:
|- org.openhab.demo.app
|--- runtime
|------- conf Here you configure the manual text files
|------- userdata Here is the openHAB user data
|------- logback.xml XML file for logging options
|--- app.bndrun The file to start OpenHAB
|--- pom.xml The pom file with all dependencies for the demo project
To let the demo project know about the add-on, the add-on must be added to the demo project
pom.xml
. Here is an example for theastro
binding:<dependency> <groupId>org.openhab.addons.bundles</groupId> <artifactId>org.openhab.binding.astro</artifactId> <version>${project.version}</version> <scope>runtime</scope> </dependency>
To run the add-on with the
app.bndrun
run configuration. Double click to openapp.bndrun
file (takes a few seconds):Under
Browse Repos
search for the add-on you want to run (astro
in our case) and add it to theRun Requirements
list using drag&drop from theBrowse Repos
list:TIP
If you cannot find the binding you want run/debug in the Browse Repos list, or the list is empty, then it is likely either the
pom.xml
of the demo project contains an error or there is a build problem with your project. Check if your project has no compile errors. Or run Maven on the command line to check if it reports any errors.Save and click "Resolve": a window with the list of resolved bundles will be shown. Click
Finish
and save the file.TIP
Watch out - it's easy to miss saving the
app.bndrun
file. If you see the little asterisk next toapp
in theapp
tab you haven't yet saved.Now the IDE is ready to start openHAB with a minimum set of the openHAB core bindings, UIs and the add-ons you configured.
Start openHAB from the IDE by clicking "Run OSGi" (upper right of the
app.bndrun
window).You can check that openHAB is running with your browser by going to: http://localhost:8080/paperui/ (opens new window) (the last
is important!)You can check log output in the
Console
tab at the bottom.Check the chosen binding is active in
Paper UI > Configuration > Bindings
Install Sources
Sources are installed by cloning the openHAB Add-ons (opens new window) repository. If you select
openHAB Add-ons
during installation the installer automatically clones the openHAB Add-ons (opens new window) repository intogit\openhab-addons
under your installation folder.If you didn't install
openHAB Add-ons
you can manually clone the openHAB Add-ons (opens new window) repository by executinggit clone https://github.com/openhab/openhab-addons.git
in thegit
folder under your installation folder.You can now modify add-on sources as needed.
Build Sources
Add the add-on as an Eclipse project so that Eclipse will build it automatically. Import the add-on project via
File > Import... > General > Existing Projects into Workspace
. Specify your add-on's source root folder (e.g.git\openhab-addons\bundles\org.openhab.binding.astro
under the installation folder) as the root folder in the wizard.Start a Debug Session
Simply start your debug session by clicking "Debug OSGi" (upper right of the
app.bndrun
window). You can now use breakpoints and all other Eclipse debug tools.
If you just run an add-on following the above steps then the required add-on jar files are retrieved through your Maven repository folder .m2/repository
(e.g. .m2\repository\org\openhab\addons\bundles\org.openhab.binding.astro
If you imported your add-on as a project then the jar file is no longer retrieved from the Maven repository, but instead from the project build (e.g. git\openhab-addons\bundles\org.openhab.binding.astro\target
under the installation folder).
# Using New Bindings
# Updating OpenHAB
You can update the OpenHAB version you are running in the IDE at any time simply by updating your git repos under your install folder.
For example to update to the latest version run git checkout
in each repo folder under your git
folder in the installation folder.
