# Google Assistant Action
# General Configuration Instructions
# Requirements
- openHAB Cloud Connector configured using myopenHAB.org (opens new window). (Items DO NOT need to be exposed to and will not show up on myopenHAB.org (opens new window), this is only needed for the IFTTT service!)
- Google account.
- Google Home, Google Home mini, Google Nest or the Google Assistant on your phone.
# Item configuration
In openHAB 2 items are exposed via metadata (opens new window).
Currently the following metadata values are supported (also depending on Googles API capabilities):
Switch / Dimmer / Color { ga="Light" }Switch { ga="Switch" [ inverted=true ] }(all Switch items can use the inverted option)Switch { ga="Outlet" }Switch { ga="Coffee_Maker" }Switch { ga="WaterHeater" }Switch { ga="Fireplace" }Switch { ga="Valve" }Switch { ga="Sprinkler" }Switch { ga="Vacuum" }Switch { ga="Scene" }Switch { ga="Lock" [ tfaAck=true ] }Switch { ga="SecuritySystem" [ tfaPin="1234" ] }Dimmer { ga="Speaker" }Switch / Dimmer { ga="Fan" [ speeds="0=away:zero,50=default:standard:one,100=high:two", lang="en", ordered=true ] }(for Dimmer the options have to be set)Switch / Dimmer { ga="Hood" }Switch / Dimmer { ga="AirPurifier" }Rollershutter { ga="Awning" [ inverted=true ] }(all Rollershutter items can use the inverted option)Rollershutter { ga="Blinds" }Rollershutter { ga="Curtain" }Rollershutter { ga="Door" }Rollershutter { ga="Garage" }Rollershutter { ga="Gate" }Rollershutter { ga="Pergola" }Rollershutter { ga="Shutter" }Rollershutter { ga="Window" }Group { ga="Thermostat" [ modes="..." ] }Number { ga="thermostatTemperatureAmbient" }as part of Thermostat groupNumber { ga="thermostatHumidityAmbient" }as part of Thermostat groupNumber { ga="thermostatTemperatureSetpoint" }as part of Thermostat groupNumber / String { ga="thermostatMode" }as part of Thermostat groupString { ga="Camera" [ protocols="hls,dash" ] }
* All Rollershutter devices can also be used with a Switch item with the limitation of only supporting open and close states.
Example item configuration:
Switch KitchenLights "Kitchen Lights" <light> (gKitchen) { ga="Switch" }
Dimmer BedroomLights "Bedroom Lights" <light> (gBedroom) { ga="Light" }
Color LivingroomLights "Livingroom Lights" <light> (gLivingroom) { ga="Light" }
Switch SceneMovie "Livingroom Scene Movie" (gLivingroom) { synonyms="Movie Scene", ga="Scene" }
Switch CristmasTree "Cristmas Tree" (gLivingroom) { ga="Outlet" }
Switch DoorLock "Door Lock" { ga="Lock" }
//Thermostat Setup (Google requires a mode, even if you manually set it up in openHAB)
Group g_HK_Basement_TSTAT "Basement Thermostat" { ga="Thermostat" [ useFahrenheit=true ] }
Number HK_Basement_Mode "Basement Heating/Cooling Mode" (g_HK_Basement_TSTAT) { ga="thermostatMode" }
Number HK_Basement_Setpoint "Basement Setpoint" (g_HK_Basement_TSTAT) { ga="thermostatTemperatureSetpoint" }
Number HK_Basement_Temp "Basement Temperature" (g_HK_Basement_TSTAT) { ga="thermostatTemperatureAmbient" }
Number HK_Basement_Humid "Basement Humidity" (g_HK_Basement_TSTAT) { ga="thermostatHumidityAmbient" }
NOTE: metadata is not (yet?) available via paperUI. Either you create your items via ".items" files, or you can:
- add metadata via console:
smarthome:metadata add BedroomLights ga Light
- add metadata using the REST API:
PUT /rest/items/BedroomLights/metadata/ga
"value": "Light"
# Special item configurations
# Two-Factor-Authentication
For some actions, Google recommends to use TFA (Two-Factor-Authentication) to prevent accidential or unauthorized triggers of sensitive actions. See Two-factor authentication | Actions on Google Smart Home (opens new window).
Switch DoorLock "Front Door" { ga="Lock" [ tfaAck=true ] }
Switch HouseAlarm "House Alarm" { ga="SecuritySystem" [ tfaPin="1234" ] }
# Thermostats
Thermostat requires a group of items to be properly configured to be used with Google Assistant. The default temperature unit is Celsius. { ga="Thermostat" }
To change the temperature unit to Fahrenheit, add the config option [ useFahrenheit=true ] to the thermostat group.
To set the temperature range your thermostat supports, add the config option [ thermostatTemperatureRange="10,30" ] to the thermostat group.
There must be at least three items as members of the group:
- (Mandatory) Mode: Number (Zwave THERMOSTAT_MODE Format) or String (off, heat, cool, on, ...).
{ ga="thermostatMode" } - (Mandatory) Temperature Ambient: Number.
{ ga="thermostatTemperatureAmbient" } - (Mandatory) Temperature Setpoint: Number.
{ ga="thermostatTemperatureSetpoint" } - (Optional) Temperature Setpoint High: Number.
{ ga="thermostatTemperatureSetpointHigh" } - (Optional) Temperature Setpoint Low: Number.
{ ga="thermostatTemperatureSetpointLow" } - (Optional) Humidity Ambient: Number.
To map the default thermostat modes of Google (opens new window) (on, off, heat, cool, etc.) to custom ones for your specific setup, you can use the modes config option on the thermostat group.
E.g. [ modes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto" ] will enable the following five modes in Google Home "off, heat, eco, on, auto" that will be translated to "OFF, COMFORT, ECO, ON, auto". You can specify alternative conversions using the colon sign, so that in the former example "BOOST" in openHAB would also be translated to "heat" in Google. For the translation of Google modes to openHAB always the first option after the equal sign is used.
By default the integration will provide "off,heat,cool,on,heatcool,auto,eco".
# Fans
Fans (and similar device types, like AirPurifier or Hood) support the FanSpeed trait. With that you will be able to set up and use human speakable modes, e.g. "fast" for 100% or "slow" for 25%.
To set up those modes use a Dimmer item and the following metadata config: [ speeds="0=away:zero,50=default:standard:one,100=high:two", lang="en", ordered=true ].
speeds will be a comma-separated list of modes with a percentage number followed by an equal sign and different aliases for that mode after a colon. So here both "high" and "two" would set the speed to 100%. You are also able to define the language of those aliases. The option ordered will tell the system that your list is ordered and you will then be able to also say "faster" or "slower" and Google will use the next or previous speed.
# Blinds and similar devices
Blinds should always use the Rollershutter item type.
Since Google and openHAB use the oposite percentage value for "opened" or "closed", the action will tranlate this automatically.
If the values are still inverted in your case, you can state the [ inverted=true ] option for all Rollershutter items.
# Setup & Usage on Google Assistant App
- Set up the voice-activated speaker, Pixel, or Android phone (version 6+) with the same account.
- Start the updated Google Home app on your phone.
- Go to the settings part:
Account > Settings.
- Go to the home control part:
Assistant > Home control.
- Press the
+button.
- Select
openHAB.
- Login at myopenhab.org (opens new window) with your username and password.
- Allow Google access to your account.
- You will now be able to see your previously configured items and devices. Assign them to a room. Press Done.
- You can now control those devices from the Google Assistant.
# Example Voice Commands
- Turn on Office Lights.
- Set Office Lights to 35%.
- Open/Close the blinds
- Turn off Pool Waterfall.
- Turn on House Fan.
- Turn on Home Theater Scene.
# Frequently Asked Question
- Say: Hey Google, sync my devices.
- Check, recheck and after that check again your items!
- The items that you want to expose to Google Assistant should have the right metadata assigned.
- The items that you want to expose to Google Assistant must have a item label! Item Definition and Syntax (opens new window)
- If you expose thermostats make sure than you have:
- A group item with the metadata value { ga="Thermostat" }
- A number or string item with the metadata value { ga="thermostatMode" } as part of the thermostat group
- A number item with the metadata value { ga="thermostatTemperatureAmbient" } as part of the thermostat group
- A number item with the metadata value { ga="thermostatTemperatureSetpoint" } as part of the thermostat group
Group g_HK_Basement_TSTAT "Basement Thermostat" { ga="Thermostat" [ useFahrenheit=true ] } Number HK_Basement_Mode "Basement Heating/Cooling Mode" (g_HK_Basement_TSTAT) { ga="thermostatMode" } Number HK_Basement_Setpoint "Basement Setpoint" (g_HK_Basement_TSTAT) { ga="thermostatTemperatureSetpoint" } Number HK_Basement_Temp "Basement Temperature" (g_HK_Basement_TSTAT) { ga="thermostatTemperatureAmbient" } - If none of the above solutions works for you:
- Remove all the metadata.
Switch TestLight "Test Light" { ga="Switch" }- Relink your account.
