# GPSTracker Binding
This binding allows you to connect mobile GPS tracker applications to openHAB and process GPS location reports.
Currently two applications are supported:
- OwnTracks (opens new window) - iOS, Android
- GPSLogger (opens new window) - Android
GPS location reports are sent to openHAB using HTTP. Please be aware that this communication uses the public network so make sure your openHAB installation is secured (opens new window) (but accessible from public internet through myopenhab.org (opens new window) or using a reverse proxy) and you configured HTTPS access in tracking applications. The easiest way to achieve this is to use the openHAB Cloud Connector (opens new window) in conjunction with myopenHAB.org (opens new window).
The binding can process two message types received from trackers:
- Location - This is a simple location report with coordinates extended with some extra information about the tracker (e.g. tracker device battery level). [OwnTracks, GPSLogger]
- Transition - This report is based on regions defined in tracker application only. A message is sent every time the tracker enters or leaves a region. [OwnTracks only] See "Distance Channel and Presence Switch" how this behavior can be achieved with openHAB's on-board tools.
# OwnTracks
Install OwnTracks for Android (opens new window) or OwnTracks for iOS (opens new window) on your device.
Go to Preferences/Connection and set:
- Mode - select Private HTTP
- Host
- https://<your.ip.address>/gpstracker/owntracks or
- https://home.myopenhab.org/gpstracker/owntracks (opens new window)
- Identification
- Turn Authentication ON
- Set username and password to be able to reach your openHAB server (myopenhab.org (opens new window) credential, if choosen as host)
- Device ID is not important. Set it to e.g. phone
- Tracker ID - This id identifies the tracker as a thing. This must be unique for each tracker connected to the same openHAB instance (e.g. family members).
# GPSLogger
Install GPSLogger for Android (opens new window) on your device. After the launch, go to General Options. Enable Start on boot-up and Start on app launch.
Go to Logging details and enable Log to custom URL. If you only want to use GPSLogger for this binding, you can disable all other "Log to" entries. Right after enabling, the app takes you to the Log to custom URL settings:
- URL
- https://<your.ip.address>/gpstracker/gpslogger or
- https://home.myopenhab.org/gpstracker/gpslogger (opens new window)
- HTTP Body - type in: { "_type":"location", "lat":%LAT, "lon":%LON, "tid":"XY", "acc":%ACC, "batt":%BATT, "tst":%TIMESTAMP }
- Note: "tid" is the tracker id that identifies the tracker as a thing. This must be unique for each tracker connected to the same openHAB instance (e.g. family members).
- HTTP Headers - type in: Content-Type: application/json
- HTTP Method - type in: POST
- Basic Authentication - Set username and password to be able to reach your openHAB server (myopenhab.org (opens new window) credential, if choosen as URL)
- Check if everything is ok by clicking on Validate SSL Certificate.
It is possible to define things manually or to use the discovery feature of the openHAB. An important detail for both methods is that a tracker is identified by a tracker id configured on mobile devices. Make sure these tracker ids are unique in group of trackers connected to a single openHAB instance.
If the things are not defined in .things files the first time the tracker sends a GPS log record the binding recognizes it as new tracker and inserts an entry into the Inbox as new tracker with name GPS Tracker ??.
Basic channels provided by the tracker things:
- Location - Current location of the tracker
- Accuracy - GPS accuracy
- Last Report - Timestamp of the last location report
- Battery Level - Battery level of the device running the tracker application
- Region trigger channel - Used by regions defined in tracker application. Event is fired with payload of the region name when the binding receives a transition log record or a distance calculation for a location record indicates that the tracker is outside of the region circle. Payload is suffixed with
/enterfor entering and with/leavefor leaving events.
# Distance Calculation
Tracker thing can be extended with Distance channels (channel type is regionDistance) if a distance calculation is needed for a region.
These dynamic channels require the following parameters:
| Region Name | String | Region name. If the region is configured in the tracker app as well use the same name. Distance channels can also be defined as binding only regions (not configured in trackers) |
| Region center | Location | Region center location |
| Region Radius | Integer | Geofence radius |
| Accuracy Threshold | Integer | Location accuracy threshold (0 to disable) |
Distance values will be updated each time a GPS location log record is received from the tracker if the accuracy is below the threshold or if the threshold is disabled.
When this calculated distance is less than the defined geofence radius the binding also fires event on Region Trigger channel.
- When the tracker is approaching (the new calculated distance is less then the previous one) the payload is <<region_name>>/enter.
- If the tracker is distancing (the new calculated distance is greater then the previous one) payload is <<region_name>>/leave.
If the tracker is moving inside/outside the region (both the previous and the current calculated distance value is less/greater than the radius) no events are fired. This means that the region events are triggered ONLY IN CASE THE REGION BORDER IS CROSSED.
Note: In case the location is set for openHAB installation (Configuration/System/Regional Settings) the binding automatically creates the System Distance channel (gpstracker:tracker:??:distanceSystem) with region name set to System.
# Tracker Location Status
In case external regions are defined in mobile application the binding fires entering/leaving events on region trigger channel. These events are fired in case of distance channels as well when the tracker crosses the geofence (the distance from the region center becomes less/greater than the radius). In order to have this state available in stateful switch items (e.g. for rule logic) switch type items can be linked to regionTrigger channel. There is a special profile (gpstracker:trigger-geofence) that transforms trigger enter/leave events to switch states:
- <<region_name>>/enter will update the switch state to ON
- <<region_name>>/leave will update the switch state to OFF
To link a switch item to regionTrigger channel the following parameters are required by the item link:
| Profile Name | Selection | Select the Geofence(gpstracker:trigger-geofence) from dropdown |
| Region Name | String | Region name which should be the same as used in the tracker application or defined for distance channels |
# Manual Configuration
//tracker definition
Thing gpstracker:tracker:1 "XY tracker" [trackerId="XY"]
//tracker definition with extra distance channel
Thing gpstracker:tracker:EX "EX tracker" [trackerId="EX"] {
Type regionDistance : homeDistance "Distance from Home" [
regionName="Home",
regionCenterLocation="11.1111,22.2222",
regionRadius=100,
accuracyThreshold=30
//items for basic channels
Location locationEX "Location" {channel="gpstracker:tracker:1:lastLocation"}
DateTime lastSeenEX "Last seen" {channel="gpstracker:tracker:1:lastReport"}
Number batteryEX "Battery level" {channel="gpstracker:tracker:1:batteryLevel"}
Number:Length accuracyEX "GPS Accuracy [%d m]" {channel="gpstracker:tracker:1:gpsAccuracy"}
//linking switch item to regionTrigger channel. assuming the Home distance channel is defined in the binding config (see above)
Switch atHomeEX "Home presence" {channel="gpstracker:tracker:EX:regionTrigger" [profile="gpstracker:trigger-geofence", regionName="Home"]}
//another switch for work region. assuming the OTWork is defined in OwnTracks application (no distance channel is needed like for Home)
Switch atWorkEX "Work presence" {channel="gpstracker:tracker:EX:regionTrigger" [profile="gpstracker:trigger-geofence", regionName="OTWork"]}
# Sitemaps
sitemap gpstracker label="GPSTracker Binding" {
Text item=distanceEX
Text item=atWorkEX
Text item=atHomeEX
Text item=lastSeenEX
Text item=batteryEX
Text item=accuracyEX
Mapview item=locationEX height=4
# Debug
As the setup is not that simple here are some hints for debugging.
In order to see detailed debug information set TRACE debug level (opens new window) for org.openhab.binding.gpstracker package.
# Binding Start
2018-10-03 18:12:38.950 [DEBUG] [org.openhab.binding.gpstracker ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService, org.openhab.binding.gpstracker.internal.discovery.TrackerDiscoveryService}={service.id=425, service.bundleid=183, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.discovery.TrackerDiscoveryService, component.id=268} - org.openhab.binding.gpstracker
2018-10-03 18:12:38.965 [DEBUG] [org.openhab.binding.gpstracker ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, org.eclipse.smarthome.config.core.ConfigOptionProvider}={location=47.536178,19.169812, service.id=426, service.bundleid=183, service.scope=bundle, radius=100, name=Home, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=267, additionalRegionsJSON=[
], triggerEvent=false, service.pid=binding.gpstracker} - org.openhab.binding.gpstracker
2018-10-03 18:12:38.994 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - Initializing callback servlets
2018-10-03 18:12:39.013 [DEBUG] [org.openhab.binding.gpstracker ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.version=2.4.0.201809241418, osgi.web.contextpath=/, service.id=427, osgi.web.symbolicname=org.openhab.binding.gpstracker, service.bundleid=183, service.scope=singleton, osgi.web.contextname=default} - org.openhab.binding.gpstracker
2018-10-03 18:12:39.047 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - Started GPSTracker Callback servlet on /gpstracker/owntracks
2018-10-03 18:12:39.058 [DEBUG] [er.internal.GPSTrackerHandlerFactory] - Started GPSTracker Callback servlet on /gpstracker/gpslogger
2018-10-03 18:12:39.072 [DEBUG] [org.openhab.binding.gpstracker ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.profiles.ProfileFactory, org.eclipse.smarthome.core.thing.profiles.ProfileAdvisor, org.eclipse.smarthome.core.thing.profiles.ProfileTypeProvider}={service.id=428, service.bundleid=183, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.profile.GPSTrackerProfileFactory, component.id=269} - org.openhab.binding.gpstracker
2018-10-03 18:12:39.092 [DEBUG] [org.openhab.binding.gpstracker ] - BundleEvent STARTING - org.openhab.binding.gpstracker
2018-10-03 18:12:39.098 [DEBUG] [org.openhab.binding.gpstracker ] - BundleEvent STARTED - org.openhab.binding.gpstracker
Please note the lines about started servlets:
# Registration
In case the discovery is used the first message from a tracker registers it in the inbox:
2018-10-05 08:36:14.283 [DEBUG] [nal.provider.AbstractCallbackServlet] - Post message received from OwnTracks tracker: {"_type":"location","tid":"XX","acc":10.0,"lat":41.53,"lon":16.16,"tst":1527966973,"wtst":1524244195,"batt":96}
2018-10-05 08:36:14.286 [DEBUG] [nal.provider.AbstractCallbackServlet] - There is no handler for tracker XX. Check the inbox for the new tracker.
# Location Update
The next location message already calculates the distance for System location:
2018-10-05 08:38:33.916 [DEBUG] [nal.provider.AbstractCallbackServlet] - Post message received from OwnTracks tracker: {"_type":"location","tid":"XX","acc":10.0,"lat":41.53,"lon":16.16,"tst":1527966973,"wtst":1524244195,"batt":96}
2018-10-05 08:38:33.917 [DEBUG] [cker.internal.handler.TrackerHandler] - Update base channels for tracker XX from message: org.openhab.binding.gpstracker.internal.message.LocationMessage@31dfed63
2018-10-05 08:38:33.941 [TRACE] [cker.internal.handler.TrackerHandler] - batteryLevel -> 96
2018-10-05 08:38:33.942 [TRACE] [cker.internal.handler.TrackerHandler] - lastLocation -> 41.53,16.16
2018-10-05 08:38:33.943 [TRACE] [cker.internal.handler.TrackerHandler] - lastReport -> 2018-06-02T19:16:13.000+0000
2018-10-05 08:38:33.943 [DEBUG] [cker.internal.handler.TrackerHandler] - Updating distance channels tracker XX
2018-10-05 08:38:33.944 [TRACE] [cker.internal.handler.TrackerHandler] - Region center distance from tracker location 41.53,16.16 is 709835.1673811453m
2018-10-05 08:38:33.944 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
# Distance Channel and Presence Switch
Assumptions:
- A Home distance channel is added to the tracker with parameters:
- Channel ID: distanceHome
- Region Name: Home
- Region Radius: 100
- Region Center: 42.53,16.16
- Presence switch is linked to the regionTrigger channel with parameters:
- Profile: Geofence(gpstracker:trigger-geofence)
- Region Name: Home
After a location message received from the tracker the log should contain these lines:
2018-10-05 09:27:58.768 [DEBUG] [nal.provider.AbstractCallbackServlet] - Post message received from OwnTracks tracker: {"_type":"location","tid":"XX","acc":10.0,"lat":42.53,"lon":17.16,"tst":1527966973,"wtst":1524244195,"batt":96}
2018-10-05 09:27:58.769 [DEBUG] [cker.internal.handler.TrackerHandler] - Update base channels for tracker XX from message: org.openhab.binding.gpstracker.internal.message.LocationMessage@67e5d438
2018-10-05 09:27:58.770 [TRACE] [cker.internal.handler.TrackerHandler] - batteryLevel -> 96
2018-10-05 09:27:58.771 [TRACE] [cker.internal.handler.TrackerHandler] - lastLocation -> 42.53,17.16
2018-10-05 09:27:58.772 [TRACE] [cker.internal.handler.TrackerHandler] - lastReport -> 2018-06-02T19:16:13.000+0000
2018-10-05 09:27:58.773 [DEBUG] [cker.internal.handler.TrackerHandler] - Updating distance channels tracker XX
2018-10-05 09:27:58.774 [TRACE] [cker.internal.handler.TrackerHandler] - Region Home center distance from tracker location 42.53,17.16 is 82033.47272145993m
2018-10-05 09:27:58.775 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
2018-10-05 09:27:58.779 [DEBUG] [ofile.GPSTrackerTriggerSwitchProfile] - Trigger switch profile created for region Home
2018-10-05 09:27:58.779 [DEBUG] [ofile.GPSTrackerTriggerSwitchProfile] - Transition trigger Home/leave handled for region Home by profile: OFF
2018-10-05 09:27:58.792 [TRACE] [cker.internal.handler.TrackerHandler] - Triggering Home for XX/Home/leave
2018-10-05 09:27:58.793 [TRACE] [cker.internal.handler.TrackerHandler] - Region System center distance from tracker location 42.53,17.16 is 579224.192171576m
2018-10-05 09:27:58.794 [TRACE] [cker.internal.handler.TrackerHandler] - System uses SI measurement units. No conversion is needed.
Note: If the binding was restarted or the distance channel is new (this is the first location message for the channel) only the second location update will trigger event as the binding has to know the previous state.
# External Region and Presence Switch
Assumptions:
- A shared region is defined in OwnTracks application. Lets call it Work.
- Region Name: Work
2018-10-05 09:35:27.203 [DEBUG] [nal.provider.AbstractCallbackServlet] - Post message received from OwnTracks tracker: {"_type":"transition","tid":"XX","acc":10.0,"desc":"Work","event":"enter","lat":42.53,"lon":18.22,"tst":1527966973,"wtst":1524244195,"t":"c"}
2018-10-05 09:35:27.204 [DEBUG] [cker.internal.handler.TrackerHandler] - ConfigHelper transition event received: Work
2018-10-05 09:35:27.204 [DEBUG] [cker.internal.handler.TrackerHandler] - Update base channels for tracker XX from message: org.openhab.binding.gpstracker.internal.message.TransitionMessage@5e5b0d59
2018-10-05 09:35:27.204 [TRACE] [cker.internal.handler.TrackerHandler] - lastLocation -> 42.53,18.22
2018-10-05 09:35:27.205 [TRACE] [cker.internal.handler.TrackerHandler] - lastReport -> 2018-06-02T19:16:13.000+0000
2018-10-05 09:35:27.205 [DEBUG] [cker.internal.handler.TrackerHandler] - Updating distance channels tracker XX
2018-10-05 09:35:27.206 [TRACE] [cker.internal.handler.TrackerHandler] - Region Home center distance from tracker location 42.53,18.22 is 168985.77453131412m
2018-10-05 09:35:27.207 [TRACE] [cker.internal.handler.TrackerHandler] - Region System center distance from tracker location 42.53,18.22 is 562259.467093007m
2018-10-05 09:35:27.208 [TRACE] [cker.internal.handler.TrackerHandler] - Triggering Work for XX/Work/enter
2018-10-05 09:35:27.208 [DEBUG] [ofile.GPSTrackerTriggerSwitchProfile] - Trigger switch profile created for region Home
2018-10-05 09:35:27.210 [DEBUG] [ofile.GPSTrackerTriggerSwitchProfile] - Trigger switch profile created for region Work
2018-10-05 09:35:27.210 [DEBUG] [ofile.GPSTrackerTriggerSwitchProfile] - Transition trigger Work/enter handled for region Work by profile: ON
Note:
- If the binding was restarted only the second transition update will trigger event as the binding has to know the previous state.
- The distance is not calculated for Work as the binding doesn't know the Work region center.
