# MQTT Binding
A server, also called broker is not provided within this binding. You can use any of the freely available MQTT Brokers like Mosquitto (opens new window) or Moquette (opens new window) or install the included Moquette broker (opens new window) as add-on.
# Supported Bridges
- SystemBroker: A system configured broker cannot be changed by this binding and will be listed as read-only system-broker.
# Bridge Configuration
Reconnect parameters are:
- lwtRetain: Retain last will message. Defaults to false.
# Supported Channels
Configuration parameters are:
# Legacy MQTT1-Binding
This binding is not supposed to run in parallel to the old mqtt1-binding. Please uninstall the old binding before installing this binding.
