# Nanoleaf Binding
Currently Nanoleaf's "Light Panels" and "Canvas" devices are supported. Note that only the canvas type does support the touch functionality.
The controller thing is the bridge for the individually attached panels/canvas and can be perceived as the nanoleaf device at the wall as a whole (either called "light panels" or "canvas" by Nanoleaf). With the controller thing you can control channels which affect all panels, e.g. selecting effects or setting the brightness.
The lightpanel (singular) thing controls one of the individual panels/canvas that are connected to each other. Each individual panel has therefore its own id assigned to it. You can set the color for each panel or turn it on (white) or off (black) and in the case of a nanoleaf canvas you can even detect single and double touch events related to an individual panel which opens a whole new world of controlling any other device within your openHAB environment.
Note: In case of major changes of a binding (like adding more features to a thing) it becomes necessary to delete your things due to the things not being compatible anymore. Don't worry too much though as they will be easily redetected and nothing really is lost. Just make sure that you delete them and rediscover as described below.
Adding the Controller as a Thing
To add a nanoleaf controller you need to go to your inbox in Paper UI, press the plus sign which starts a scan (you can of course use habmin for that as well). Then choose "Nanoleaf Binding". A controller (also known as bridge) device is discovered automatically through mDNS in the local network. Alternatively, you can also provide a things file (see below for more details). After the device is discovered and added as a thing, it needs a valid authentication token that must be obtained by pairing it with your openHAB instance. Without the token the light panels remain in status OFFLINE.
- Make sure that the authentication token field in your Nanoleaf controller thing configuration is left empty.
- Hold down the on-off button of the controller for 5-7 seconds until the LED starts flashing/cycling in a pattern, which turns the device in pairing mode, and openHAB will try to request an authentication token for it.
Adding the invidual light panels as a thing
After you have added the controller as a thing and it has been successfully paired as described as above, the individual panels connected to it can be discovered by starting another scan for the Nanoleaf binding (e.g. from the Inbox in Paper UI). All connected panels will be added as separate things to the inbox.
Troubleshooting: In seldom cases (in particular together with updating the binding) things or items do not work as expected, are offline or may not be detected. In this case
- stop and then start openHAB
Knowing which panel has which id
Unfortunately it is not easy to find out which panel gets which id while this is pretty important if you have lots of them and you want to assign rules to it. Don't worry: the binding comes with some helpful support in the background the canvas type (this is only provided for the canvas device because triangles can have weird layouts that are hard to express in a log output)
- fire up your browser and open the openHAB server on port 9001 which shows the logs.
- Set up a switch item with the channel panelLayout on the controller (see NanoRetrieveLayout below) and set the switch to true
- look out for something like "Panel layout and ids" in the logs. Below that you will see a panel layout similar to
31413 9162 13276
58086 8134 39755
41451
Disclaimer: this works best with square devices and not necessarily well with triangles due to the more geometrically flexible layout.
| Config | Description |
| address | IP address or hostname of the light panels controller (e.g. 192.168.1.100) |
| port | Port number of the light panels contoller. Default is 16021 |
| authToken | The authentication token received from the controller after successful pairing. |
| refreshInterval | Interval in seconds to refresh the state of the light panels settings. Default is 60. |
| deviceType | (readOnly) defines the type: lightpanels (triangle) or canvas (square) |
| id | ID assigned by the controller to the individual panel (e.g. 158) |
The IDs of the individual panels can be determined by starting another scan once the controller is configured and online. This will add all connected panels with their IDs to the inbox.
| Channel | Item Type | Description | Read Only |
| power | Switch | Power state of the light panels | No |
| color | Color | Color of all light panels | No |
| colorTemperature | Dimmer | Color temperature (in percent) of all light panels | No |
| colorTemperatureAbs | Number | Color temperature (in Kelvin, 1200 to 6500) of all light panels | No |
| colorMode | String | Color mode of the light panels | Yes |
| effect | String | Selected effect of the light panels | No |
| rhythmState | Switch | Connection state of the rhythm module | Yes |
| rhythmActive | Switch | Activity state of the rhythm module | Yes |
| rhythmMode | Number | Sound source for the rhythm module. 0=Microphone, 1=Aux cable | No |
| panelLayout | Switch | Set to true will log out panel layout (returns to off automatically | No |
| panelColor | Color | Color of the individual light panel | No |
| singleTap | Switch | [Canvas Only] Is set when the user taps that panel once (1 second pulse) | Yes |
| doubleTap | Switch | [Canvas Only] Is set when the user taps that panel twice (1 second pulse) | Yes |
color and panelColor
The color and panelColor channels support full color control with hue, saturation and brightness values. For example, brightness of all panels at once can be controlled by defining a dimmer item for the color channel of the controller thing. The same applies to the panelColor channel of an individual lightpanel thing.
What might not be obvious and even maybe confusing is the fact that brightness and color use the same channel but two different itemTypes. While the Color-itemtype controls the color, the Dimmer-itemtype controls the brightness on the same channel.
Limitations assigning specific colors on individual panels:
- Due to the way the API of the nanoleaf is designed, each time a color is assigned to a panel, it will be directly sent to that panel. The result is that if you send colors to several panels more or less at the same time, they will not be set at the same time but one after the other and rather appear like a sequence but as a one shot.
- Another important limitation is that individual panels cannot be set while a dynamic effect is running on the panel which means that the following happens
- As soon as you set an individual panel a so called "static effect" is created which replaces the chosen dynamic effect. You can even see that in the nanoleaf app that shows that a static effect is now running.
- Unfortunately, at least at the moment, the colors of the current state cannot be retrieved due to the high frequency of color changes that cannot be read quickly enough from the canvas, so all panels go to OFF
- The the first panelColor command is applied to that panel (and of course then all subsequent commands)
Touch Support
Nanoleaf's Canvas introduces a whole new experience by adding touch support to it. This allows single and double taps on individual panels to be detected and then processed via rules to further control any other device! Note that even gestures like up, down, left, right are sent but can only be detected on the whole set of panels and not on an individual panel. These four gestures are not yet supported by the binding but may be added in a later release.
To detect single and double taps the panel's have been extended to have two additional channels named singleTap and doubleTap which act like switches that are turned on as soon as a tap type is detected. These switches then act as a pulse to further control anything else via rules.
If a panel is tapped the switch is set to ON and automatically reset to OFF after 1 second (this may be configured in the future) to simulate a pulse. A rule can easily detect the transition from OFF to ON and later detect another tap as it is automatically reset by the binding. See the example below on Panel 2.
- Within the nanoleaf app go to the dashboard and choose your device. Enter the settings for that device by clicking the cog icon in the upper right corner.
- Enable "Touch Gesture" and assign the gestures you want to happen but set the double tap to unassigned.
- To still have the possibility to switch on the whole canvas device with all its panels by double tapping a specific panel, you can easily write a rule that triggers on the double tap channel of that panel and then toggles the Power Channel of the controller. See the example below on Panel 1.
# nanoleaf.things
If you define your device statically in the thing file, autodiscovery of the same thing is suppressed by using
# nanoleaf.items
Note: If you did autodiscover your things and items:
- A controller item looks like nanoleaf:controller:F0ED4F9351AF:power where F0ED4F9351AF is the id of the controller that has been automatically assigned by the binding.
Switch NanoleafPower "Nanoleaf" { channel="nanoleaf:controller:MyLightPanels:power" }
String NanoleafHue "Hue [%s]"
Number NanoleafColorTempAbs "Color temperature [%.000f]" { channel="nanoleaf:controller:MyLightPanels:colorTemperatureAbs" }
Switch NanoRetrieveLayout "Nano Layout" { channel="nanoleaf:controller:D81E7A7E424E:panelLayout" }
Color Panel1Color "Panel 1" { channel="nanoleaf:lightpanel:MyLightPanels:135:panelColor" }
Dimmer Panel1Brightness "Panel 1" { channel="nanoleaf:lightpanel:MyLightPanels:135:panelColor" }
Switch Panel1DoubleTap "Toggle device on and off" { channel="nanoleaf:lightpanel:MyLightPanels:135:doubleTap" }
Switch Panel2Color "Panel 2" { channel="nanoleaf:lightpanel:MyLightPanels:158:panelColor" }
Switch Panel2SingleTap "Panel 2 Single Tap" { channel="nanoleaf:lightpanel:MyLightPanels:158:singleTap" }
Switch Panel2DoubleTap "Panel 2 Double Tap" { channel="nanoleaf:lightpanel:MyLightPanels:158:doubleTap" }
# nanoleaf.sitemap
Frame label="Controller" {
Switch item=NanoleafPower
Text item=NanoleafHue
Text item=NanoleafSaturation
Slider item=NanoleafColorTemp
Text item=NanoleafColorMode
Selection item=NanoleafEffect mappings=["Color Burst"="Color Burst", "Fireworks" = "Fireworks", "Flames" = "Flames", "Forest" = "Forest", "Inner Peace" = "Inner Peace", "Meteor Shower" = "Meteor Shower", "Nemo" = "Nemo", "Northern Lights" = "Northern Lights", "Paint Splatter" = "Paint Splatter", "Pulse Pop Beats" = "Pulse Pop Beats", "Rhythmic Northern Lights" = "Rhythmic Northern Lights", "Ripple" = "Ripple", "Romantic" = "Romantic", "Snowfall" = "Snowfall", "Sound Bar" = "Sound Bar", "Streaking Notes" = "Streaking Notes", "moonlight" = "Moonlight", "*Static*" = "Color (single panels)", "*Dynamic*" = "Color (all panels)" ]
Text item=NanoleafRhythmState
Switch item=NanoRetrieveLayout
Frame label="Panels" {
Colorpicker item=Panel1Color
Slider item=Panel1Brightness
Colorpicker item=Panel2Color
Frame label="Scenes" {
Note: The mappings to effects in the selection item are specific for each Nanoleaf installation and should be adapted accordingly. Only the effects "*Static*" and "*Dynamic*" are predefined by the controller and should always be present in the mappings.
# nanoleaf.rules
rule "UpdateHueAndSat"
rule "ShowRainbowScene"
val long pause = 200
var hue = 0
var direction = 1
Thread::sleep(pause)
hue = hue + (5 * direction)
if(hue >= 359) {
hue = 359
direction = direction * -1
else if (hue < 0) {
hue = 0
Item Panel2SingleTap changed from NULL to ON or
Item Panel2SingleTap changed from OFF to ON
sendCommand(My_Main_Light,ON)
Item Panel1DoubleTap changed from NULL to ON or
Item Panel1DoubleTap changed from OFF to ON
sendCommand(NanoleafPower,ON)
# nanoleaf.map
ON = Yes
OFF = No
effects = Effect
hs = Hue/Saturation
ct = Color Temperature
