# NeoHub Binding
The binding supports the following types of Thing..
| Thing Type | Description |
| NeoHub | The Heatmiser NeoHub bridge which is used to communicate with NeoStat and NeoPlug devices |
| NeoStat | Heatmiser Neostat Smart Thermostat |
| NeoPlug | Heatmiser NeoPlug Smart Plug |
| NeoContact | Heatmiser Contact Sensor, wireless door or window contact |
| NeoTemperatureSensor | Heatmiser Wireless Air Sensor, wireless temperature sensor |
You have to manually create a single (Bridge) Thing for the NeoHub, and enter the required Configuration Parameters (see Thing Configuration for NeoHub below). If the Configuration Parameters are all valid, then the NeoHub Thing will automatically attempt to connect and sign on to the hub. If the sign on succeeds, the Thing will indicate its status as Online, otherwise it will show an error status.
Once the NeoHub Thing has been created and it has successfully signed on, it will automatically interrogate the HeoHub to discover all the respective Heatmiser device Things that are connected to it. If in the future, you add additional Heatmiser devices to your system, the binding will discover them too.
The NeoHub Thing connects to the hub (bridge) to communicate with any respective connected Heatmiser device Things. It signs on to the hub using the supplied connection parameters, and it polls the hub at regular intervals to read and write the data for each Heatmiser device. The NeoHub supports two Application Programming Interfaces "API" (an older "legacy" one, and a modern one), and this binding can use either of them to communicate with it. Before the binding can communicate with the hub, the following Configuration Parameters must be entered.
| hostName | Host name (IP address) of the NeoHub (example 192.168.1.123) |
| portNumber | Port number of the NeoHub (Default=4242) |
| pollingInterval | Time (seconds) between polling requests to the NeoHub (Min=4, Max=60, Default=60) |
| socketTimeout | Time (seconds) to allow for TCP socket connections to the hub to succeed (Min=4, Max=20, Default=5) |
| preferLegacyApi | Prefer if the binding should use the legacy API; this only works so long as the legacy API is still supported; otherwise the binding will switch to the new API anyway (Default=false) |
The NeoHub Thing connects to the hub (bridge) to communicate with any Heatmiser devices that are connected to it. Each such Heatmiser device is identified by means of a unique device name in the hub. The device name is automatically discovered by the NeoHub Thing, and it is also visible (and changeable) via the Heatmiser App.
| deviceNameInHub | Device name that identifies the Heatmiser device in the NeoHub and the Heatmiser App |
# Channels for "NeoHub"
| meshNetworkQoS | Number:Dimensionless | RF mesh network Quality-of-Service; this is the percentage of configured devices that are currently connected online via the RF mesh network |
| roomTemperature | Number:Temperature | Actual room temperature |
| floorTemperature | Number:Temperature | Actual floor temperature |
| thermostatOutputState | String | Status of whether the thermostat is Off, or calling for Heat |
| occupancyModePresent | Switch | The thermostat is in the Present Occupancy Mode (Off=Absent, On=Present) |
| batteryLowAlarm | Switch | The battery is low (only applies for battery powered thermostats) (Off=Ok, On=Alarm) |
| plugOutputState | Switch | The output state of the plug switch (Off, On) |
| plugAutoMode | Switch | The plug is in Automatic Mode (Off=Manual, On=Automatic) |
| contactState | Contact | The state of the contact |
| batteryLowAlarm | Switch | The battery is low (Off=Ok, On=Alarm) |
| sensorTemperature | Number:Temperature | Actual measured temperature |
Occasionally it is possible that a device might drop out of the mesh.
If a device drops out of the mesh, you can select whether openHAB shall either a) change the Channel value to UNDEF, or b) hold the value that it had prior to the drop out.
The choice of a) or b) is determined by an optional Channel configuration parameter holdOnlineState as follows.
| holdOnlineState | Switch | If the respective device drops out of the RF mesh, the behaviour is as follows: - Off: openHAB changes the Channel's state to UNDEF- On: openHAB holds the Channel's state unchanged The default setting is Off |
The purpose of holdOnlineState is so you can choose to overlook value fluctuations if drop outs occur e.g. to "hold" the values in a temperature graph display.
Note: if a drop out occurs, the Thing will always change its status to OFFLINE (irrespective of the holdOnlineState setting).
# demo.things File
# demo.items File
# demo.sitemap File
Frame label="Thermostat" {
Frame label="Plug" {
Frame label="Contact" {
Frame label="Sensor" {
Text item=Kitchen_Temperature
