# Nikobus Binding
This binding allows openHAB to interact with the Nikobus home automation system.
More specifically, it allows openHAB to:
- send (simulated) button presses to the Nikobus,
- react to button presses which occur on the Nikobus,
- change the status of switch channels on a Nikobus switch module,
- request the status of switch channels on a Nikobus switch module,
- change the status of dimmer channels on a Nikobus dimmer module,
- request the status of dimmer channels on a Nikobus dimmer module,
- send commands to the Nikobus roller shutter module.
This binding works with at least the following hardware:
- PC-link module (05-200),
- Push buttons (05-060-01, 05-064-01), RF Transmitter (05-314), PIR Sensor (430-00500),
- 4 channel switch module (05-002-02),
- 12 channel switch module (05-000-02),
- 12 channel dimmer module.
The binding supports a serial connection via nikobus:pc-link bridge to the Nikobus installation (PC-Link module):
The bridge enables communication with other Nikobus components:
switch-module- Nikobus switch module, i.e.05-000-02,dimmer-module- Nikobus dim-controller module, i.e.05-007-02,rollershutter-module- Nikobus roller shutter module,push-button- Nikobus physical push button.
The binding does not support any automatic discovery of Things.
# Bridge Configuration
The binding can connect to the PC-Link via serial interface.
Bridge nikobus:pc-link:mypclink [ port="<serial port>", refreshInterval=<interval> ] {
where:
portis the name of the serial port used to connect to the Nikobus installationrefreshIntervaldefines how often the binding reads Nikobus module's status, so having i.e. 30 as above, the binding will read one module’s status each 30s, iterating through all modules, one by one. If one does not specifyrefreshInterval, a default value of 60s is used.
Once connected to the Nikobus installation using a bridge, one can communicate with:
switch-module,dimmer-module,rollershutter-module,push-button.
# Modules
Each module is defined by its address and contains 12 outputs (channels), where output-1 corresponds to module's first output, output-2 to module's second output and so on.
If physical module has less outputs, only those channels can be used (i.e. 05-002-02 has only 4 outputs, so only channels 1-4 can be used).
Large module contains 2 channel groups, where the first group controls channels 1-6 and the second one controls channels 7-12. The small module contains only a single channel group controlling all 4 channels.
All commands sent to/received from the Nikobus switch module are for a single channel group.
In order to be able to read the status of a Nikobus module channel or to switch a channel directly on the module without mimicking a button press, items for each channel of a module needs to be configured.
# switch-module
Thing switch-module s1 [ address = "BC00" ]
Defines a switch-module with address BC00.
| channel | type | description |
| output-1 | Switch | Output 1 |
| output-2 | Switch | Output 2 |
| output-3 | Switch | Output 3 |
| output-4 | Switch | Output 4 |
| output-5 | Switch | Output 5 |
| output-6 | Switch | Output 6 |
| output-7 | Switch | Output 7 |
| output-8 | Switch | Output 8 |
| output-9 | Switch | Output 9 |
| output-10 | Switch | Output 10 |
| output-11 | Switch | Output 11 |
| output-12 | Switch | Output 12 |
# dimmer-module
Thing dimmer-module d1 [ address = "D969" ]
Defines a dimmer-module with address D969.
| output-1 | Dimmer | Output 1 |
| output-2 | Dimmer | Output 2 |
| output-3 | Dimmer | Output 3 |
| output-4 | Dimmer | Output 4 |
| output-5 | Dimmer | Output 5 |
| output-6 | Dimmer | Output 6 |
| output-7 | Dimmer | Output 7 |
| output-8 | Dimmer | Output 8 |
| output-9 | Dimmer | Output 9 |
| output-10 | Dimmer | Output 10 |
| output-11 | Dimmer | Output 11 |
| output-12 | Dimmer | Output 12 |
# rollershutter-module
Thing rollershutter-module r1 [ address = "4C6C" ]
Defines a rollershutter-module with address 4C6C.
| output-1 | Rollershutter | Output 1 |
| output-2 | Rollershutter | Output 2 |
| output-3 | Rollershutter | Output 3 |
| output-4 | Rollershutter | Output 4 |
| output-5 | Rollershutter | Output 5 |
| output-6 | Rollershutter | Output 6 |
# Buttons
Once an openHAB item has been configured as a Nikobus button, it will receive a status update to ON when the physical button is pressed.
When an item receives the ON command from openHAB, it will send a simulated button press to the Nikobus.
This means one could also define virtual buttons in openHAB with non-existing addresses (e.g., 000001) and use those in the programming of Nikobus installation.
To configure an item for a button in openHAB with address 28092A, use the following format:
Thing push-button pb1 [ address = "28092A" ]
Since all the channels in the entire channel group are switched to their new state, it is important that openHAB knows the current state of all the channels in that group. Otherwise a channel which was switched on by a button, may be switched off again by the command.
In order to keep an up to date state of the channels in openHAB, button configurations can be extended to include detail on which channel groups the button press affects.
When configured, the status of the channel groups to which the button is linked, will be queried every time the button is pressed. Every status query takes between ~300 ms, so to get the best performance, only add the affected channel groups in the configuration, which has the following format:
Thing push-button <id> [ address = "<address>", impactedModules = "<moduleType>:<moduleId>:<channelGroup>, <moduleType>:<moduleId>:<channelGroup>, ..." ]
where:
moduleTyperepresents module's type,moduleIdrepresents module's id,channelGrouprepresents the first (1) or second (2) channel group in the module.
Example configurations may look like:
Thing switch-module s1 [ address = "FF2A" ]
Thing push-button pb1 [ address = "28092A", impactedModules = "switch-module:s1:1" ]
In addition to the status requests triggered by button presses, there is also a scheduled status update interval defined by the refreshInterval parameter and explained above.
# nikobus.things
Bridge nikobus:pc-link:mypclink [ port = "/dev/ttyUSB0", refreshInterval = 10 ] {
Thing dimmer-module d1 [ address = "0700" ]
Thing dimmer-module d2 [ address = "6B00" ]
Thing switch-module s2 [ address = "4C6C" ]
Thing switch-module s3 [ address = "A063" ]
Thing rollershutter-module r1 [ address = "D769" ]
Thing push-button 92092A "S_2_1_2A" [ address = "92092A", impactedModules = "switch-module:s1:1" ]
Thing push-button D2092A "S_2_1_2B" [ address = "D2092A", impactedModules = "switch-module:s1:1" ]
Thing push-button 12092A "S_2_1_2C" [ address = "12092A", impactedModules = "dimmer-module:d1:1" ]
Thing push-button 52092A "S_2_1_2D" [ address = "52092A", impactedModules = "dimmer-module:d1:1" ]
Thing push-button 1EE5F2 "S_2_3_A" [ address = "1EE5F2", impactedModules = "dimmer-module:d1:2" ]
Thing push-button 5EE5F2 "S_2_3_B" [ address = "5EE5F2", impactedModules = "dimmer-module:d1:2" ]
Thing push-button 0C274A "S_2_4_A" [ address = "0C274A", impactedModules = "dimmer-module:d1:2" ]
Thing push-button 4C274A "S_2_4_B" [ address = "4C274A", impactedModules = "dimmer-module:d1:2" ]
Thing push-button 1D1FF2 "S_2_5_A" [ address = "1D1FF2", impactedModules = "switch-module:s1:1" ]
Thing push-button 5D1FF2 "S_2_5_B" [ address = "5D1FF2", impactedModules = "switch-module:s1:1" ]
# nikobus.items
Dimmer Light_FF_Gallery_Ceiling "Ceiling" (FF_Gallery, Lights) [ "Lighting" ] { channel="nikobus:dimmer-module:mypclink:d1:output-1" }
Dimmer Light_FF_Bed_Ceiling "Ceiling" (FF_Bed, Lights) [ "Lighting" ] { channel="nikobus:dimmer-module:mypclink:d1:output-7" }
Dimmer Light_FF_Child_Ceiling "Ceiling" (FF_Child, Lights) [ "Lighting" ] { channel="nikobus:dimmer-module:mypclink:d2:output-10" }
Dimmer Light_FF_Child_Wall_Left "Wall Left" (FF_Child, Lights) [ "Lighting" ] { channel="nikobus:dimmer-module:mypclink:d1:output-11" }
Dimmer Light_FF_Child_Wall_Right "Wall Right" (FF_Child, Lights) [ "Lighting" ] { channel="nikobus:dimmer-module:mypclink:d1:output-12" }
Dimmer Light_FF_PlayRoom_Ceiling "Ceiling" (FF_PlayRoom, Lights) [ "Lighting" ] { channel="nikobus:dimmer-module:mypclink:d1:output-6" }
Dimmer Light_FF_PlayRoom_Wall "Wall" (FF_PlayRoom, Lights) [ "Lighting" ] { channel="nikobus:dimmer-module:mypclink:d1:output-4" }
Switch Light_FF_Gallery_Wall "Wall" (FF_Gallery, Lights) [ "Lighting" ] { channel="nikobus:switch-module:mypclink:s1:output-4" }
Switch Light_FF_Bath_Ceiling "Ceiling" (FF_Bath, Lights) [ "Lighting" ] { channel="nikobus:switch-module:mypclink:s3:output-2" }
Switch Light_FF_Wardrobe_Ceiling "Ceiling" (FF_Wardrobe, Lights) [ "Lighting" ] { channel="nikobus:switch-module:mypclink:s1:output-1" }
Switch Light_FF_Corridor_Ceiling "Ceiling" (FF_Corridor, Lights) [ "Lighting" ] { channel="nikobus:switch-module:mypclink:s2:output-3" }
Rollershutter Shutter_GF_Corridor "Corridor" (GF_Corridor, gShuttersGF) { channel="nikobus:rollershutter-module:mypclink:r1:output-1" }
Rollershutter Shutter_GF_Bed "Bedroom" (GF_Bed, gShuttersGF) { channel="nikobus:rollershutter-module:mypclink:r1:output-3" }
Rollershutter Shutter_GF_Bath "Bathroom" (GF_Bath, gShuttersGF) { channel="nikobus:rollershutter-module:mypclink:r1:output-2" }
Rollershutter Shutter_FF_Child "Child's room" (FF_Child, gShuttersFF) { channel="nikobus:rollershutter-module:mypclink:r1:output-4" }
Rollershutter Shutter_FF_Gallery "Gallery" (FF_Gallery, gShuttersFF) { channel="nikobus:rollershutter-module:mypclink:r1:output-5" }
