# Tellstick Binding
dimmer - Switchable Device - On/Off only could be lamps or other electronic equipment.
switch - Sensors - Temperature- and humidity-sensors.
sensor
telldus-core - Telldus Live Bridge - Telldus Cloud service, all devices with online access.
telldus-live
Switchbased sensors workaround
switchThings instead of typecontact. There is technically no way of distinguish them apart from regulurswitchThings. For using them as sensors only (not paired to a lamp) please consult the workaround in the channel section.
Devices which is added to Telldus Core and Telldus Live can be discovered by openHAB.
When you add this binding it will try to discover the Telldus Core Bridge. If it is installed correct its devices will show up. If you want to use the Telldus Live its bridge, Telldus Live bridge need to be added manually.
# Binding Configuration
Only the bridges require manual configuration.
It is preferable that devices and sensors are discovered automatically; let the discovery/inbox initially configure them.
You can add them either with karaf: inbox approve <thingId> or by using the inbox of the Paper UI.
# Dimmers & switches
Use the option repeat for that. Default resend count is 2.
# Bridges
Depending on your tellstick device type there is different ways of using this binding.
The binding implements two different API:
Not implemented yet but supported by some new devices, contributions are welcome. API documention. (opens new window)
3) Local Rest API is a local API which would work similar to Telldus Live but local.
| Model | Telldus Core | Telldus Live | Local REST API | Verified working with openHAB |
| Tellstick Basic | X | X | X | |
| Tellstick Duo | X | X | X | |
| Tellstick Net v.1 | X | |||
| Tellstick Net v.2 | X | X | ||
| Tellstick ZNet Lite v.1 | X | X | X | |
| Tellstick ZNet Lite v.2 | X | X |
# Telldus Core Bridge
java -d32 -versionFor changing architecture in Linux check out:
dpkg --add-architecture
Optional:
# Telldus Live Bridge
To configure Telldus Live you have request OAuth tokens from Telldus. Goto this page https://api.telldus.com/keys/index (opens new window) and request your keys and update the config.
Required:
- privateKey: Private key
- publicKey: Public key
- token: Token
- tokenSecret: Token secret
Optional:
| dimmer | Number | This channel indicates the current dim level |
| state | Switch | This channel indicates whether a device is turned on or off. |
| timestamp | DateTime | This channel reports the last time this device state changed. |
| humidity | Number:Dimensionless | This channel reports the current humidity in percentage. |
| temperature | Number:Temperature | This channel reports the current temperature. |
| timestamp | DateTime | This channel reports the last time this sensor was updates. |
| watt | Number:Power | This channel reports the current watt. |
| ampere | Number:ElectricCurrent | This channel reports the current ampere. |
| windgust | Number:Speed | The current peak wind gust. |
| winddirection | Number:Angle | The current wind direction. |
| windaverage | Number:Speed | The current wind average. |
| rainrate | Number:Length | This current rate of rain. |
| raintotal | Number:Length | The total rain. |
All switchbased sensors are binary and the goal is to represent them as a contact item in openHAB. Eg. a door is open or closed and can't be altered by sending a radio signal.
rule "proxy_front_door_on"
rule "proxy_front_door_off"
# tellstick.things
# tellstick.items
